Ive just bought a capacitor for my new setup (Soundstream 5 Farad cap) and just wondering if there any "Dont's" associated with the install? As i understand they can be a bit nasty if 'accidentally' discharged.
I am drawing up a basic wiring diagram and just wanting to confirm exactly what happens with the capacitor is this right?
Power wire from battery to capacitor
Then continue to the power input on the amp
With the earth does the amp get earthed via the cap or do I run an earth for the amp and a second one for the cap? or is the cap not earthed seperately?
Any advice would be great
This is what I have bought so far
Pioneer Splits (Already installed)
P4004 Rockford amp
P3 10' Rockford sub
Soundstream 5farad capacitor
Later on I will buy a monoblock and run a second P3 sub and also move the pioneer speakers into the rear of the car and buy some decent focal splits for the front.
I will have my old sub and amp to sell (less than a year old) not sure what they are worth
The sub is a kicker 10' dual voice coil sub (the silver shiny patterned cone one)
and the amp is coustic 4 ch.
I cant remember how much I paid for these, any ideas what I should ask for when I sell them?
https://www.sau.com.au/forums/topic/126148-how-to-install/
you got a 5 farad capacitor for A 10 inch sub? how much you pay?
dont get me started on capacitors. i ran a 12" with 950wrms thru it and i hammered it everytime i drove the car... the most modification i did for the power is re earth the car with a bigger guage cable and bought a better battery (was still 'only' a Bond silver/calcium battery).
never had a flat battery except for one time i left the interior light on over a long weekend.
https://www.sau.com.au/forums/topic/126148-how-to-install/#findComment-2330490
Iv'e got a positive cable from battery to cap and a negative cable from batter to cap.
and left the amps the way they were, battery to amp, amp grounded to the body.
Essentially it works out to be the same as what your saying... shouldn't matter whether you get the power for the amp from the cap or the battery, its all the same wire.
Im an ameture though :( so get a 2nd opinion...
on the same topic, does the cap help save the battery from going dead that much?? I got it to stop my lights from dimming when the sub thumped.
https://www.sau.com.au/forums/topic/126148-how-to-install/#findComment-2330752
Hey Heath, you are on the money here, power to cap then amp, as for the negative it shouldnt matter if you give it a seperate earth or not. You are also right about an accidental discharge, there is a lot of potential energy stored in them and they are designed to discharge very quickly, hopefully the worst thing that would happen is that it would scare the sh*t out of you :banana: -keep that in mind when you are removing it too, they will stay charged for days after being unhooked from the battery.
Also, they wont stop your battery from going flat as they only store charge that is already there, they can not create power, cheers
https://www.sau.com.au/forums/topic/126148-how-to-install/#findComment-2333302
Thanks for that mate
I think I will run a common earth for battery and cap then. I remember playing with very little caps at school playing pranks on people with them, and the TINY ones still hurt, this is a lot bigger so i suppose the hurt will be a lot bigger too.
Now it is just a case of watching the tracking updates on the net and waiting for the postman!!
https://www.sau.com.au/forums/topic/126148-how-to-install/#findComment-2333522
Paid a few hundred for it, looking to upgrade later so I thought I would be better off doing things properly the first time -cheaper in th long run.
I get a flat battery all of the time, dont think the cap will help that (i think its the alarm draining my battery) thinking about possibly installing a second battery in parallel. I do get a few blown headlights though due to the constant dimming with the base. Hopefully that will stop now
You are 100% right, any cap will not help your battery from running flat. It wont help with your headlights dimming etc.
Honestly, if you are having problems with your lights dimming to the point where the hedlights fail due to lack of voltage you need to
- upgrade your alternator
- upgrade your regulator
- upgrade all the earths from your main devices, engine, battery, chasis.
If you do decide to put in a second battery without doing these you will just run that battery down to.
As for your alarm draining your battery, it is possible, but highly unlikely, an alarm at rest ( not going off) draws very little current and wont make your car go flat. Check to see if your boot light is staying on or some other device is constantly active. This will drain the battery.
https://www.sau.com.au/forums/topic/126148-how-to-install/#findComment-2335434
the main 'dont' when it comes to capacitors is buying/using/installing one in the first place. while i haven't much experience with these, i believe what the pro's write. take a look on car audio australia as to what they say about caps.. a general consesis is 'uterly useless'
if u want to stop lights dimming, upgrade all earths, get a better battery, upgrade charge wire from alternator to battery, make sure all ground/connections are clean with good contact
https://www.sau.com.au/forums/topic/126148-how-to-install/#findComment-2360246
Thanks for the advice mate... I might sell the cap (i bought one for my bro too)
Any idea what they are worth? ive seen 1farad ones selling for like $400and ive got a 5 farad one (soundstream too). My brother was told they are worth about $1000 at autobahn :S crazy (he is the one that bought it for me actually)
If i can sell it for enough $ it should pay for a new alternator/wiring etc
Good news re battery drain though....it WAS the alarm after all
Damn idiots installed it incorrectly to begin with :happy:
All fixed for under $100 at an auto elec
https://www.sau.com.au/forums/topic/126148-how-to-install/#findComment-2371504
Wow, people are getting ripped the hell off.
A small auxiliary battery would shit all over a capacitor for energy storage. The pulse current of a cap might be a bit higher but if you're drawing that much current you won't have much hearing left soon.
https://www.sau.com.au/forums/topic/126148-how-to-install/#findComment-2374309
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
