I know this is a skyline appreciation forum but i have always been open minded about cars. If the XR6t had been around when i bought my GTS25t i would have had a much more difficult time deciding on buying my skyline.
In the following link they say that with a couple of tweaks and some extra boost you get 252rwkw out of the XR6t. How tuff is that. Also they say that 300rwkw would be a "doddle", that will really put the wind up someone driving a HSV with 300 flywheel kw.....
http://www.fordforums.com/showthread.php?t...25&pagenumber=1
I think it is impressive that a local manufacturer has finally come up with a MODERN performance car. None of this single cam push rod junk but a really serious peice of gear. Mind you dont get me started on how the intercooler is plumbed because that really was a MAJOR COMPROMISE.
https://www.sau.com.au/forums/topic/12619-ford-xr6t/
bolting on a turbo doesn't instantly makes it a well refine sportcar as a skyline. but it does help the falcon street cred though. if u get a chance hurl one into a sweeper at the same rate as u would do in a skyline and see how much room there is left in ur undies. It's still a family car in the end.
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-230877
Hungry 6 have you tried driving one????
It is more of a family car than a race car (skyline being a race car of course) as such it will weigh more.
I personally hate the way the intercooler/ inlet manifold/ turbo is piped because it is a compromise. BUT you cant argue with a family car that pulls 240kW running 6psi which is heavily detuned. Oh by the way can your car seat 4 people as comfortably as a XR6t???
I took one for a run and i was surprised at how the suspension combined with the traction control made the car stick under serious accelaration through some cornering. The sales person did get a bit edgy at times but i assured him that i was looking at upgrading from the GTS25t to a family car with some go (cough cough like hell i was).
They didnt JUST bolt on a turbo if you check the specs they also dropped the static compression ratio and did a lot of heat shielding among other things.
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-230969
My mate works for the company that makes Ford's transmissions, and agrees the manual is at an end for torque handling, they have been leaning on it for years and keep asking to do what it was never designed to do, with this in mind the 5 spod doesnt do that bad a job.
He has worked primarily on the auto, and with him having driven my 32 GTST many times when im pissed and egging him on, he has a good idea what my car can do.
For the record the guy isnt full of BS, and claims despite the weight of the car, and saloon heritage, the development mules that he R & D flog my GTSt in accelaration, have great brakes, and handle great. He says with the handling you just have to be mindful the it is a production car with a pretty hefty kerb weight, so no brakes/heavy acceleration mid corner/ebtry to corner etc, be smooth and it can do the job. Hell he has driven the thing on great ocean road.
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-231153
I've heard from a few sources that the XR6t has a boost limit of 7psi.
Once it hit's 7psi the ECU starts to pull back timing and then starts the boost cut - just like some R33 gts-t's hit at 12psi.
If this is true, it'd be a pain in the butt to go to a full ECU change on such a modern car for a few extra psi :D
They are nice cars though. Boss at work has a blue one... Nice......
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-231353
There was a good article in the last HPI comparing the XR6 Turbo to the Supra. They said "The closest thing to a Japanese car to come out of Australia. We can't praise the XR6T any more than that".
I think the guy doing the review was a little biased as he owns a Supra, but hey, what can you do?
The writer goes on about how the 2JZ-GTE is the greatest and most proven engine of all time, whereas the 240T still has to prove it's self. "The few players in the aftermarket who have tested the 240T engine have come away confused and frustrated with an uncooperative managment system, and intercooler/exhaust systems that are far from optimum".
Apparently the LPG spec rods are a must for a serious build-up.
They also said that the Ford doesn't like to be revved!
All in all though, I think Ford is onto a good thing. However, if I was looking for a sporty family car, I'd still by a WRX!
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-232077
OK
Firstly it is a 4ltr. Motors with large swept capacity dont need to rev much because the have bulk torque early on in the rev range where as my RB25DET needs to be revved to get any go out of it.
For a sporty family car i would think it is ideal because you get a large turbo six with auto. You can be as lazy as you want to be and you can seat 4 passengers with large arses comfortably.
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-232092
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
    • If I had logged into the forum and saw that I would have  Missed out again.
