Looking to contert my GTR to run a single BOV instead of the pair, does anyone know if this is possible, plausible??? Does anyone make a kit for this or has someone done one to give me a head start?? Havent really had a look behind there yet, any help would be appreciated.
https://www.sau.com.au/forums/topic/126240-gtr-single-bov-conversion/
  • 3 weeks later...
the stock ones are the best. end of story.
if you just want the noise : then any workshop with a welder could do it for you.
a bov regardless of type can hold infinate boost. if hooked up corectly. "pascals law" lol
if its got boost presure trying to open it. its got the SAME boost pushing on the other side keeping it shut! aswell as whatever the spring tension is aswell. so its imposible for it to leak physicly.
unless the seat area is worn obvoiusly
i tryed 2 hks ssq ones and they didnt work for shit. well they did work. but the amount of compressor surge i was getting was retarded.
the greddy type R kit for GTR replaces the whole stock assembly with 1 BOV. the stock ones are fine. having said that I run twin Blitz ones (to atmo) on my GTR and have no stalling, no idle problems, no compressor surge. And it's running AFMs and a PFC (standard version). So I dont quite know what all the fuss is about?
What improvement did you notice when you changed from the standard BOV's?
:rofl: cheers :P
i never said there was any improvment, gary. :) In fact in my post I said the stock ones are fine. I was just pointing out that I've had zero problems running twin, atmo BOVs. and the reason they are there is they were already fitted to the car when I bought it. If it had had stock ones they would still be there, BUT I'm not going to pull off something that works perfectly well (and sounds cool!) to return to stock. just because other people have problems I've yet to experience either with the stock ECU or the PFC.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
