Looking to contert my GTR to run a single BOV instead of the pair, does anyone know if this is possible, plausible??? Does anyone make a kit for this or has someone done one to give me a head start?? Havent really had a look behind there yet, any help would be appreciated.
https://www.sau.com.au/forums/topic/126240-gtr-single-bov-conversion/
  • 3 weeks later...
the stock ones are the best. end of story.
if you just want the noise : then any workshop with a welder could do it for you.
a bov regardless of type can hold infinate boost. if hooked up corectly. "pascals law" lol
if its got boost presure trying to open it. its got the SAME boost pushing on the other side keeping it shut! aswell as whatever the spring tension is aswell. so its imposible for it to leak physicly.
unless the seat area is worn obvoiusly
i tryed 2 hks ssq ones and they didnt work for shit. well they did work. but the amount of compressor surge i was getting was retarded.
the greddy type R kit for GTR replaces the whole stock assembly with 1 BOV. the stock ones are fine. having said that I run twin Blitz ones (to atmo) on my GTR and have no stalling, no idle problems, no compressor surge. And it's running AFMs and a PFC (standard version). So I dont quite know what all the fuss is about?
What improvement did you notice when you changed from the standard BOV's?
:rofl: cheers :P
i never said there was any improvment, gary. :) In fact in my post I said the stock ones are fine. I was just pointing out that I've had zero problems running twin, atmo BOVs. and the reason they are there is they were already fitted to the car when I bought it. If it had had stock ones they would still be there, BUT I'm not going to pull off something that works perfectly well (and sounds cool!) to return to stock. just because other people have problems I've yet to experience either with the stock ECU or the PFC.
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
