hi there!
just a quick question... i am about to purchase a set of wiseco pistons with 87mm bore on GTR rods removed from an RB26 block, and was wondering whether my RB25 block can take these parts?
and if so, how much HP/boost can I push due to the thinner cylinder walls? or wont this have any effect?
thanks guys,
Nico
https://www.sau.com.au/forums/topic/126243-quick-question-on-engine-internals/
Have you got your motor apart yet?
I personally wouldnt bore anymore than i needed too.
Like, if your motor is A-ok and you can get 86mm in there after machining etc, then thats what i would do.
But then there are some using 87mm without issues i *think*... someone will confirm as im sure there are a few :P
hi there!
thanks guys,
Nico
It seems as though you are doing something similar to me.
I just bought the bits I need to build an rb25 with 87mm rb26 wiseco pistons stock rb26 rods and rb26 crank.
To use gtr rb26 pistons you have to use a gtr crank.
If you're using an rb25 crank then you can use the rb26 rods with rb25 pistons.
I was going to buy 2nd hand rb26 wisecos with rb26 rods but with new rings it would have cost nearly as much as new pistons.
I bought new wiseco pistons, cometic head gasket,acl race bearings and arp rodbolts/headstuds for a very good price
Boring 87mm shouldn't affect block strength too much and I'm not worried about leaving material for further rebuilds as 2nd hand rb25 blocks cost a lot less than forgies.
hmm...
this is bad news... i am about to buy RB26 rods with RB26 87mm Bore Wisecos on them...
so you are saying that they will not fit on my RB25 block?? what if i use a 1.6mm cometic HG?
is there actually any chance of these RB26 fitting onto my RB25 crank?
THanks!
Nico
rb25 and rb26 rods are almost identical, except rb26 rods are beefier so using them with rb25 pistons is fine as long as you're using the rb25 crank. the rods arent the issue.
to use rb26 pistons in an rb25 block, you'll need an rb26 crank. no machining is required to do so, and ive seen some floating around for around the $150-200 mark.
the rb26 has a larger throw, which is the reason you've got the .1L extra in capacity. using the rb26 rods on an rb25 crank will give you really shit compression as the throw is smaller.
RB26 and RB25 conrods are the same length
RB26 has 2 mm longer stroke than RB25
Hence an RB26 piston has the gudgeon pin 1 mm lower than an RB25 piston
So if you want to use RB26 pistons with an RB25 crank you need to machine 1 mm of the block to achieve the correct deck height,
Note that because of the smaller capacity of the RB25 (compared to the RB26) the compression ratio will be slightly lower than would be the case if you used those pistons in an RB26
None of which is a big deal
:D Cheers :D
:D Cheers :O
aha ok...
so I can use 87mm Wisecos from RB26 and GTR Rods on my RB25 block with crank :(
dont you think that instead of having to machine 1mm of the block (see attached pict) away, it would be easier using a 1,6mm cometic head gasket? isnt that an alternative?
Thanks for helping guys :wave:
Edited by T-u-R-b-O
aha ok...
if im not mistaken 1.6mm is BIGGER than a std gasket thickness...
so using that instead of taking the 1mm of the block will make everything WORSE ..
your taking 1mm off the block to INCREASE the compression... adding a larger gasket REDUCES compression..
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
