I've installed water methanol injection. I got the shits with our 95 ron fuel here, and wanted something worth tuning to. The Results were fantastic - able to put in up to 7 degrees advance on full load, and 2 psi more boost (GT30 at 18psi)
This kit is a detonation destroyer.
Car runs like a nut case now.
I didn't want the kit on all the time so I hooked up a relay, and pinched a signal wire from the washer bottle motor power. The Washer bottle motor power comes on as soon as you turn the key.
As for the Washer bottle itself, I cut the larger half off (it's such and overkill anyway!) and had it plasti welded up for $70. That way, I could retain the wiring, mounts etc. It was suggested I buy a smaller washer bottle but I would have hd to wire it up, and find one with dual motors (for the rear windscreen too). It was much easier reducing the size of the original bottle. The Dude that welded it even welded in the original lid!
The jet - Since the cast is fairly thin, I opted to drill and tap a hole through one of the mounts where its a little thinker. It was a little too thick (the jet only has so much thread, plus it's tapered) so we had to grind the mount down a little. The jet MUST be flush with the inside of the pipe.
These systems work even better on 98ron fuel......... Can't wait.
I have a mate running one with av gas - Supra with over 500hp at the wheels.
Let me know what you all think..
Edited by The Mafia
  • Replies 61
Excellent job mate! Congratulations great system i always new they did the job, i have used one on a supecharger setup, huge difference power wise heaps more timing and boost, funny thing is do you actually need an intercooler because i didnt?? Also what ratio are you running 50/50?? You could also put some nitro in there to give it a little more kick ;)
Definately need an intercooler. I'm in the process of installing a 225ml\m jet before the intercooler. THis will greatly inprove the intercoolers performance. The methanol will drop the intercooler temperature by a heap, improving its performance.
Yeap, 50% Water, 50% Methanol. When you say Nitro? What do you mean? Nitrous Oxide or somethin else that I can put in the water methanol mix? Always up for "secret" additives. Are there any downsides to it?
How much was it if you dont mind me asking?
The Stage II Kit can be had from Full Throttle Performance for $850. (http://www.full-throttle.com.au/Engine/Boost%20Cooler.htm) I know thats a fair amount, but put it this way. The Pumps they use are shureflow pumps - They are worth at least $300 on their own, and they are considered the best on the market. (my dad is a cane farmer, and he was even shoked to see the kit come with that particular branded pump, and straight away said they are very high quality pump.) The jets are also of excellent quality, they mist the water meth mix so well, it almost looks like steam. As for the variable controller - You'll never find an activation point like that. Gradually feeds the car water, not dumping it in giving the car flat spots. They also have controllers that read MAF voltage. The more air, the more water.
How does this system actually work.
what does it do?
This sytem injects water and methanol into the air intake. The Water stabilises the fuel burn preventing detonation) and the methanol drops your inlet tempteratures by about 15 degrees.
Other good side effects - It cleans everything. Open up a motor that has had water methanol injection and you'll find it'll be much cleaner then a normal motor.
Edited by The Mafia
Hey good work.
If your car is now tuned for water/meth then what happens when you run out?
heh...It pings its nuts off on boost.
So, its simple. You don't let it run out. The 2l mix lasts for about 1 tank of fuel. Soits easy to keep topped up.
There are 2 things to be careful with this setup hydrolic lockup, if not set up correctly water can seap into the cylinders and if you do run out of the methanol mix and your car is tuned to run it :D it will ping and blow the pistons to pieces. You have to make sure the tank is at the lowest point possible and that you have a non drip nozzle or water injector. Have attached a simple diagram below of a system easy to setup yourself guys and as mafia has noticed a good power gain from more timing advance and boost!
You can add nitro methol instead of methanol ;) gives a much better explosion when burnt you can get it from any speed shop im pretty sure thats what they run in the supercharged v8's.
The Boost cooler has these options.
1. SolenoidValve to stop it syphoning on vaccum, or bleeding under weight when the car is off.
2. Reverse Check Valve. Stops boost blowing back to the pump.
I don't need to worry, as my tank and pump a mounted well below the nozzle.
It is still better to use an intercooler, howver - you do not need to go to a big front mount. We tested the same kit on our circuit car with no intercooler, and found that on the longer straights, temps were well controlled, but on tighter, on/off throttle situations, and on partial throttle where you are not using much/any boost, the water alone was not able to give a consistant inlet temp.
We have just installed a new intercooler - not huge, and already we have seen lower intake temps and higher HP figures on the dyno.
Mafia - the pic of the contol module shows you having both dials set at the same amount (approx 5psi)..... is this how you are running the system in the car? You should have the full PSI set at about 14psi in your application (assuming you are running 18psi)...this will then allow you to run a larger nozzle to add more water/meth at the top end.
Mark.
Mark.
Nope, got the water on full at about 12psi - 14psi - Just remember that list dial is very sensitive. 5 - 15psi in that tiny little bit of adjustment.
Hi why are you running 18psi with the stock bov they start leaking at 10.
allso how much is the methanol per 2L
I just bought a drum of methanol - 20l for $40
DO NOT RUN NITRO.. if its the stuff that im thinking off.. a few people i know as a joke decided to run some in there lawn mower.. f**k it went hell hard.. didnt start again after that tho :banana: even tho using the nitro in this case wouldnt use stuff all compared to the lawn mower.. it will still f**k your engine eventualy just keep it simple and run it as watermethanol.. wat it was designed for.
Mafia,
hey good to see someone else enjoying the benifits of water & methanol injection.
It would have to be one of the most overlooked, engine safety devices, & cheap horse power available, and dates back to the 1st world war or before, still around & it works.
I got a coolingmist kit from the US. no flash controllers, just boost operated microswitch, 3.9 US Gallons per Hour Nozzle (360-500HP rated), 150PSI Pump, one way check valve. easilly upgradeable to a dual stage as HP increases. http://www.coolingmist.com/detailmain.aspx?pid=02P
i purchased it for the same reason as yourself, except we only have 91 octane here..................nothing else!! (unless i run Avgas all the time $$$$$$$$$$$$$$)
currently running 1.2bar (17.4PSI) with the water/meths cutting in at 0.95bar (13.8PSI)
fantastic stuff................................
can feel the difference, even when running Avgas with the water/meths
versatile, when u run out of Methanol, just run water, still cools the intake charge & minimizes pinging.
i use 60/40 or 30/70 water & Metholated spirits, metho is 95/96 pure Ethanol & i can't buy Methanol in PNG anyway. but even if i cant get metho, i can use Isoprply Alchohol, Xylene, pure Ethanol, toluene............
Question,
have you had any problem with Ignition Breakdown at low boost?
what plug gap are you running?
Any plans to have dyno tuned?
i would love to see a run up on no water/Meths (keeping an eye on knock of course) & then a run with!!
that's be awesome, please post it if you do.
i only have a innovative motorsports A/F meter & at the moment so can only log A/F, RPM & TPS nothing like a dyno unfortunately, but at least allows me to see what my engine is doing as i add mods.
here's pic of a log file at 1.1bar, WOT run 1st, 2nd, 3rd & 4th with the water/meths inj turned on.
you can see distintly where the water/meths kicks in. i have quite big laggy turbo's that don't start to spool up till around 0.7bar, (then all hell breaks loose :D ) so you can see at around 75% of the max revs in each gear where the A/F dropps (richens) is where it is kicking in & doing what i't supposed to.
unfortunately i can't monitor Knock at the moment, (but have an Apexi Power FC to put in soon), & i'm running the Std RB26DETT timing. so real keen to get the FC in so i can monitor knock & play with the advance.
Mafia, would love to hear of any further tests or results with regards to water/meths injection.
Mafia,
Question,
you can see distintly where the water/meths kicks in. i have quite big laggy turbo's that don't start to spool up till around 0.7bar, (then all hell breaks loose :wave: ) so you can see at around 75% of the max revs in each gear where the A/F dropps (richens) is where it is kicking in & doing what i't supposed to.
Hi Png Godzilla,
I too have purchased a cooling mist system - mine being the one with computer controlled cooling mist controller, clog nozzle detector, bronze check valve etc. The cooling mist controller is pretty cool as you can adjust your maps via laptop if you want.
I'll be fitting it around december time and I was just wondering if you've installed your nozzle before the intercooler or after like Mafia?
Cheers
hey gtst25,
so you've got a cooling mist kit also!!
i got the clog nozzle detector, bronze check valve ect, just not the controller. Clog nozle detecor works well, light stayed on once & that's what it was.....................clogged nozzle!
Mounting..............they said to me as far back from the intake plenum as possible, but on the out side of the intercooler, so i've got mine on the first bend on the out side of the FMIC. i got the M3 injector, which was too big & caused ignition breakdown until i put my new garrets on, more huff, now it works fine :wave:
nozzle behing front drivers side spoiler grill
digital intake temp gauge & LED for when Water/Meths is activated under right corner of Gready boost controller
Digital Tem Gauge probe, boost controlled microswitch & header tank
in hindsight, after reading Mafia's post, i will take the nozzle out & turn it 180deg, (or maybe just swap the IC pipe over so the feed is facing down, also relocate the clog detector to somewhere below the nozzle. less likely to siphon that way.
don't want to hijack mafia's thread, but would love to hear more about the variable controller, i opted out as i wanted something simple. but sounds like it might be the go.
what nozzle did you get??
no info anywhere on Water/meths inj on skylines that i've found, hopefully we can all share experiences :(
7 degree's is roughly what I experienced between 91ron and 98. :wave:
    • Yeah, thumbsup from me. The distant shot of the bay just looks same-same as before.
    • Dad had a court case drag out with them from 1998 to 2004. He was in a not at fault accident, NRMA were the ones who covered the other person. They tried to blame his neck injuries on the fact he'd had an injury in 1981 on his extreme lower back where he slipped a single disc right near the bottom. Had been all cleared from that injury for years. This accident destroyed his shoulder, and f**ked a heap of discs in his neck, and he still has major problems with it to this day. Sarah's sister while on her L plates had a small Suzuki Alto, she had stopped to give way to an ambulance, and someone changed lanes behind her because there lane was also slowing, and rear ended her at 80km/h. (She had been stopped for a few seconds already too!). Car was completely f**kED. NRMA sent the vehicle around to 3 different workshops as they kept claiming "We believe it can be repaired, and not written off, we just need to find the correct workshop". It took 3 months, and a lot of arguing before they'd concede and wrote it and paid out. About two years later her sister had a Lancer, someone pulled out of a stop sign without stopping (in an 80 zone). Her sister swerved, hit the front of the other persons car (Instead of dead t-boning the drivers door), which ramped her Lancer, and made it roll multiple times down the road. It hit every panel on the way through. Her sister had slid her self out of the car, and remembers the ambos walking to the accident (They'd been sitting at a set of lights just down the road and witnessed it) and they were saying "Well, this ones going to be a fatality, no way you can walk away from that". Well, she did. And then NRMA sent two assessors out to look at the car, both of which wrote it off. They tried to send another assessor out, except a HUGE uproar was raised, and they FINALLY paid it out. That was on a car, that had damage to EVERY panel, you could see from 100m away the whole car was also twisted, roof bowed etc. Nah, we'll try get out of needing to payout on a $10,000 car... Her sister ended up with major shoulder reconstructive surgery being required, and was permanently limited in her ability to do her job as a nurse after that, as she can't (And was told before surgery too this would be guaranteed to happen) regain full strength in that shoulder. However, there was no choice to not have it, as she could barely use her arm, which was her dominant one, and was in near constant major pain. (And she's the type of person that would try and walk off a broken leg!) NRMA did the biggest run around on the personal injury side too for about 18 months, even to the point of trying to put 100% blame of the accident on Sarah's sister, even though the other driver admitted she didn't look, and didn't stop, and was charged by the police. Sarah used to have a Barina insured with them. It was a policy setup, paid all 12 months in advance. At the end of the 12 months, Sarah was living with me, I reviewed the renewal, it clearly stated "If you do nothing, your policy will cease on XYZ date". We did nothing, as we moved her insurance in with all of mine and I was with Shannons. We find out 10 months later, NRMA decided, because he DAD had a car insurance policy at the same address as what Sarah's mailing address was (Garaged address had been changed), that they'd put Sarah's (What should have been non existent policy) onto her Dad's month to month charges on his credit card. We had to jump through hoops, to get a refund. They didn't care that we actually found the letter that said "If you do nothing, your policy will cease" they made us prove we had NON COMPULSORY insurance else where before they'd issue the refund, and after they agreed to the refund, it still took another 6 weeks and 3 more phone calls for them to actually process it. They also had two insurance claims from storm damage, and they were an absolute cluster to get resolved as well (one vehicle, one house). Some how, up until about 3 years ago, her parents were still loyal to NRMA too, and we were like "How the hell are you so loyal to staying with them, when other places are so much cheaper, and they've f**ked you over every time you've ever had to make a claim?"
    • I got the four AN10 fitting welded up to the cam covers and started up making the head to sump breather/drain lines. The front passenger side cover I used a 45 up top and a 90 at the bottom into the stock VCT head drain spot (3/4" BPST to AN10 adapter) thats unused on the RB25DET NEO with some speedflow flame shield to protect it from the manifolds heat.   back passenger side was a 90 up top with some flame shield and 45 at the sump end. The rear drivers is 45 at both ends   the front drivers fitting is capped off for now but ready to go if i want to try moving the breathers around. I was told by the fabricator to leave all the welds raw for now to make sure there are no pin hole leaks. A lot of cleaning up, re bundling looms and degreasing to go as well as final assembly on the cam cover baffles. The first real test will be 28th March at a Circuit event. added complexity and more spots for leaks but overall looks relatively neat imo
    • Yeah i think the dash needs to come out. To get the loom or maybe just climate control and radio cluster. My mirrors are done i think the motors don’t work so well after flood haha i need the ac fan, you said you wanted to keep it for your 31 and interior loom not including boot. The wiper motor. I’m not sure how good the window surrounds are on the exterior on the pintara.  I will message you to get your bank details shortly
    • Just another barrier put up to stop cars being modified. When we're all driving Chinese sewing machines, you won't want to modify it anyway, and you'll likely already have slashed your wrists and be locked up in a padded room for your own protection.
