hi guys,
what is your opinion on running the intercooler piping back under the cooler and up the same side as the air box. i have been told that in order to run it up the battery (driver) side i will have to install a smaller battery facing longways. As it is an auto dont want to run out of charge and have to get jump started. as i have already purchased cooler with pipe goung out either side do you think the bend back under the pipe will be too restricting?
https://www.sau.com.au/forums/topic/126336-fmic-piping/
hi guys,
This is the style of pipework I use, goes though the inner guard under the battery in the Stagea (under the windscreen washer bottle in the picture which is an R33GTST, they have the batttery in the boot).
:P cheers :P
Edited by Sydneykid
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2332581
I have piping that comes out under my battery, but I have a smaller battery, BUT I dont really need a smaller battery, for pics go through the pics in the link in my sig, I cfb right now :P
FYI My Oddessy battery has 880CCA, and it is teeeny tiny!
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2332586
SKA- i was looking at your pics of your fmic piping under the battery tray, and i was wondering if your piping sits lower than your chassis?
But i think what stagon is talking about is running the piping through the battery tray ie:cutting a hole in the battery tray meaning he would have to turn the battery so it sits side on so the piping fits through with the battery still there.
like with most fmic kits you buy for 180's and skylines etc...
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2332828
just a question when running the intake side under the battery tray through the side i now have no room for my window washer bottle :banana: hows everyone else doing it with the same setups??? or do u just get a smaller washer bottle from soemthing else????
mines the 26 but it still runs through the same spot just under the battery tray but just above the chassis rail.
ideas peoplz???
heres a pic of where my pipe runs through the body
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2333085
Yes Cyrus, you are wrong. Your pipes go under your chassis rails like mine did. You have no hole cut.
As far as how low it sits, ive never had any problems at all with hitting my pipes. Infact, they sit pretty high compared to the front bar.
My pipes are for sale if anyone is interested.
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2333592
cost me $250 and a case of beer all up, once i sold my standard intercooler :whistling:
only thing im yet to do is mount the "Modified" washer bottle
hey andy is that a modified stock stagea washer bottle is it or another one from a different car?
i gotta sort something out for mine now that i can actually drive the old girl ;)
my piping (3") and greddy type r bov (big sucker) are under the spot so i got absolutely stuff all room unfortunately. might have to make up an aluminium one to suit the room i have.
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2335313
i gotta sort something out for mine now that i can actually drive the old girl :whistling:
i just cut off a section of the washer bottle, and used some plastic from a bucket to cover where it was chopped off. then used silicone to stop any leaks. not the most professional job but it sits inside the drivers side inner gaurd so you cant see it anyway.
i still havnt figured out how i will mount it yet, i'll work something out when i get around to putting it back on
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2335375
I'd be a fan of getting a front feed manifold, or midifying the standard to front feed, for less clutter.
Ive heard that the shorter the inlet tract, the better the throttle response... thats what its about in the end, right? perfomance? id make it a short as possible. im not one for dressy engine bays, function over from under the bonnet.
MAKE it fit!
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2335377
So has anyone actually cut the battery tray so the intercooler pipe can go through there.
Not the side like cruiseliner but the top section the actual battery tray?
So, where would the battery go? I know i dont want a battery in the same cabin as me incase I roll over and get battery acid all over me.
This isnt a Silvia :whistling:
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2335473
i think you may be right there, jason. Cos it is designed to be side fed, really. But a GTR inlet manifold... would it fit, and would it be a better option? I can get greddy front feeds from a supplier in japan. worth it? or not unless you really go big?
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2335511
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
