Hey guys,
Car security systems.
Which are the good ones, which are the bad?
Im on the sunshine coast, so who should i ring etc etc?
An immobiliser is a must and a proximity alarm would be great...
any ideas?
cheers guys.
https://www.sau.com.au/forums/topic/126440-security-system/
Hey guys,
any ideas?
cheers guys.
sambo,
give me a ring during the day and I'll have a chat to you. (0407 102 839)
the two above posters I have done recently one was scarey to look done by a local shop at the other was a recent job that wont go ANYWHERE without the owner knowing. :whistling:
https://www.sau.com.au/forums/topic/126440-security-system/#findComment-2335258
sambo,
the two above posters I have done recently one was scarey to look done by a local shop at the other was a recent job that wont go ANYWHERE without the owner knowing. :cheers:
I also agree about the quality of Chris's work - I could have had the auto-electric place around the corner from my place install an alarm, but i too decided to travel a quite a few suburbs to get Chris to do mine; it essentially came down to reading the opinions on this site and then i figured I want someone who appreciates cars the same way I do to be working on mine and yup the work was neat and tidy. It's that little extra peace of mind you get when the quality of the install is done very well. I guess you just got to ask yourself - do you want someone working on your car who has had the quality of their work verified by multiple sources or do you want to take a chance with someone else?
https://www.sau.com.au/forums/topic/126440-security-system/#findComment-2372170
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
