  • Replies 103
Originally posted by red900ss
I have no problem with speed cameras outside schools. If it saves one kid then it's worth it. :)
Remember these are little individuals who don't always know or think about what's goping on around them.
Typical thought process: "there goes ball, must get ball..."
now speed cameras on multilane roads and freeways and Spit Hill is another matter all together... :D
Dino, this one I think.
Ivan, you know, this was probably directed at primary school children...I'm sure you've seen kids run onto a road without looking...imagine how you'd feel if you ran someone over, whether or not it was your fault.
Well, I'm no fan of speed limits, but in built up areas, with cars parked on either side, it is VERY hard to see someone coming from behind the car.
And it has been proven that speed makes a significant differance to stopping distance. I'd rather drive 20km/h slower and miss the kid
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
