I just need a few pictures of most angles of a STOCK r33 gts-t engine so i can see if the turbo visable...
because i have a stock gts r33 non turbo skyline since im on my P's and i wanna put a stock turbo in and run 6-8psi...
and i wanna know if its easily seen by the eye i dont want cops to catch me out...
SO PLEASE POST R33 TURBO ENGINE PICS ( MOST ANGLES NEEDED )
Thanks for ur help
https://www.sau.com.au/forums/topic/126486-police-and-turbo-info-needed/
Thanks for ur help
I know you cant see factory turbos on a stock motor as its covered by a heat shield....
But you do understand that you will have to do other things as well if you bolt on a turbo????
what would i have to do... i only wanna run 6-8psi...therefore u dont have to change pistons and cams ect...?
All i thought i would have to do is... buy a turbo manifold and a stock turbo and bolt it on???
is this not correct?
im not gonna run high psi cause i know it will blow me engine
Nah you need a bit of modification to run a turbo, even if its at low boost. Stock rb25's only run low boost and as said above, its pretty obvious if you have a turbo... :ermm:
Correct me if i'm wrong but if you do put a turbo on and then have an accident you'd be screwed. Presumeably your insurance company would'nt pay and you would cop the 7 demerit point fine for driving a restricted vehicle, thus lose your licence>>P plater. Is it really worth it?
Thanks for ur help
If you want to treat a copper like an idiot eg: "Its a stock N/A sir, I swear", then you will be treated like a smartarse and probably have the book thrown at you.
Also, as mentioned, what happens if you kill someone, maim or just destory someone else's car and don't have any insurance ? Just a case of "I hope no one saw me hit that person/car?".
Your not allowed too have a turbocharged car - accept it.
JUST CUT HOLE IN FIRE WALL HAVE MANIFOLD AN INTAKE PIPE LEADING THROUGH FIRE WALL
INTO GLOVE BOX WHERE YOU CAN HAVE YOUR STANDARD TURBO RUNNING 6 POUNDS AND THE COPS WONT KNOW TRUST ME ITS A GOOD IDEA!!!
Edited by villain
Your also gonna need a intercooler, even the factory one is visible.... Even though some cops couldn't tell a engine from their elbow, im sure they will spot the factory intercooler or piping...
just my 2 cents
I notice you have a carbon skin bonnet - you have enough to worry about if a cop pulls you over without having a turbo hidden in the glovebox/under the bonnet.
yes, trying to get away with adding a turbo to an already LOOK AT ME!! car is asking for trouble.
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
