Hi,
I have finally got the operating manual for the GTR 4WD Controller I am building almost finished. A few guys have been interested in the controller as it has been seen at my track days being tested. The White R32 GTR, number plate 'cut' was testing it (came 2nd on May 2) as well as the die hard blue GTR.
Can I post the manual here and a brief description so you guys can see what I'm building, or is that against the forum rules. I'd prefer to keep it to the Qld section at this stage as I know you guys. I don't want to cause any problems so I thought I would ask first ?
Thanks
Paul
https://www.sau.com.au/forums/topic/126488-moderator-question/
Hi,
Thanks
Paul
Paul
Let me get this clear,
Its your 4wd controller that you built?
and you have written the manul for it?
then you hold the copyright to it and you can do whatever you like with it!
thanks for making QLD no. 1
nice work
I have finally got the operating manual for the GTR 4WD Controller I am building almost finished. A few guys have been interested in the controller as it has been seen at my track days being tested. The White R32 GTR, number plate 'cut' was testing it (came 2nd on May 2) ...
is that Rejon?
anyway, I'd be interested to see/hear more about this controller too.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
