Hey guys im thinking about selling the Skyline.
However its only to get some cash together to start another skyline project.
What do you think price i can get.
Here are the specs.
Most Important first. Hehe
Quarter mile time : 12.797 @109 mph
hp : 290 + (on dynometer)
!989 Nissan Sillhuette
Engine specs
RB20det (1992 r32 spec)
Big Front mount intercooler
Modified Plenum Chamber.
4000km High flow VG30det turbo With T04e Compressor wheel
Rated at 450+ hp
GTR Fuel pump
Full 3 Inch exhaust system with some muffler and 2 resonators.
The dump pipe on the turbo is very very good, has a separate wastegate line which connects to the exhaust system futher down. very good for flow and boosting.
Other specs
Autoclutch 9 puck 2400 lb clutch and pressure plate
Mines Modified Ecu
Blitz Dual SBC Boost controller
Bigger GTS brakes
Lowered Suspension
As the car is today there are a few things that could be fixed straight away. These are gearbox and diff mainly which i will get fixed within a month or two.
What type of money would i be looked at getting for this? The car has got easily another .2 or .3 seconds in the quarter mile with a bit of sorting.
It has bigger brakes and rotors that are yet to be fitted as well.
Im also probably forgetting a few things..
https://www.sau.com.au/forums/topic/12649-thinking-of-selling-the-silly/
I reckon $10k-$12k absolute max. Remember its a 1989 car, depending on its condition. For a few bucks more you can get a stock 180sx or silvia or for a bit more again you can get a r32 or r33 gtst. Given its fairly well modified, but you never get back what you spend on mods. Its a bit of a sleeper like daves volvo :P
$10k - $12k for an 89 car, what are you people nuts?
It's a fast car, yes Lagwagon.. but i'd say you'd be lucky to get $8k for it....
As much as we don't like to admit it, our 1993 'lines are work about $14k in a PRIVATE sale..... there's NO money in it, only loss.
Originally posted by rob77
heh... buy more houses in area's where there is huge growth. Make more profit, buy a mines or hks r34 gtr, run 9's down at kwinana... there's a plan :D
And when your 50 lagwagon you could afford your r34GTR cause then theyll be worth the same as your GTS :D
Robbie that would be the smartest idea but that is a long term investment plus like he said a house doesnt pull 10s
hey dude, you will get an easy 10k for it in perth have seen less go for that much but depends on condition. i might be interested at that price as i have been waiting for my r31 since jan, i signed a contract with the importer (it is not a personal import) but the delivery date was for feb 20, wondering if this makes the contract void??? pm me more details on body & condition etc and we can go from there, i have the money just depends on the situation with the contract i have signed, cheers
i got 10K for my 88 ZX so it is possible. But as people said the market aint the great for it and you'll get a lot of tyrekickers! Put it at 10 -12K see how much interest that generates and if people are finding it too high then drop it.
Good luck :D Hope u get what your looking for!
Strich9ine.
A car that runs a 12 comes with a certain price tag, no matter what the year or condition.
Fast times = dollars.
Going back a few years, it used to be a general rule a car that could run 13's was worth 10K min, no matter what year/ condition. Times have changed but principal still applies.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
