hay everyone as the tittle states in selling my skyline
Price: $1500
a little about the car its the pacific glow colour (bluey silver) its manual and lowerd on kings low with moroe shocks its got a s3 bar on the front its got lukey extractors and a 21/2 inch zorst system with a cannon on end very loud aftermarket leads winscreen needs replacing its got a short shifter aftermarket steering wheel towbal paint fade on boot roof and bonnet had a new motor put in like 250 k's ago shit radio 6x9 at back 6 inch sony speakers at front with speaker pods for 6 inch splits clear front indercators made but not fitted tyres are bold not much for road worthy and its unrego wheels not inclued or depending on sale
Contact details: u can contact me on my mobile 0423698696 or home phone 33661023 or email me [email protected]
https://www.sau.com.au/forums/topic/126497-qld-nissan-skyline-r31-modified/
and... it comes with the pursuits, or the 4 spokes? plz say 4 spokes.
from the short shifter - its a manual?
Much driveline chatter? hows the box?
and for me the most important thing - is it making decent power, or is it clapped out a bit?
thanks! rob
well i wasnt selling it with the rims but if i get mabe a higher price or somthing i might sell them with the pursuits on the back cause i only got 2 and the 4 spokes on front cause i only got 2 the 4 spoke have awsome tyres with like 75% tread back ones are slicks and yes the car is manual gear box is fine new clutch (just another standard one no hd clutch) diff doesnt make a noise and the tail shaft is fine to so nothing wrong with the drive line yah i could say its making decent power we went and took it for a mountain run up near samford and we hit a 160 in 4th and we wernt really pushing it so yah its got power cheers jamie
damnit... if only you were in Vic... roughyl how many kms on the engine/gearbox and what about the rest of the car?
good luck with the sale tho, looks damn good for the price.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
