the size i carnt quite rember ,but not that big aroung the 215-220 as a rule but does vary and the stock afm runs out at around the same ,so you need a higher resoulution one ie, z32 but you will need a pfc or some form of piggy back setup ie.safc to run the afm, what are you wanting to do with the car and what is alredy done to it, and power goal.
Edited by gtstcoupe
If i'm not wrong it'll be about 140ish rwkw stock as i saw my mate's GTT with just pod and full exhaust ran a 160ish rwkw on the dyno.
Stock injectors will definitely support 200rwkw. It'll be JUST right. Yes with stock AFM as well. Any higher than that, you might consider changing.
I said this in another topic but may be of interest in here as well.
For the reference also the R34 RB25 Neo injectors are top feed high impedence 370cc.
Unsure if you remember or not but on the High Performance Imports DVD's they did a skyline dyno with different mods on an R34GTT.
This engine has higher output compared to R33 model (206kw vs 187kw)
On the Croydon Dyno Dynamics Dyno it pulled the following figures.
1. 100% Stock R34 GTT Car 148rwkw (R33 should be less then this power)
2. 3" Turbo Back Exhaust - 158rwkw (stock cat still)
3. Boost increase to 10psi - 181rwkw (remember R34 has bigger turbine housing)
4. FMIC & 13psi boost - 200rwkw
5. GCG Highflow, 14psi boost + PowerFC - 225rwkw (injectors 100% duty no more boost can be added safely)
Hope that can bring something to convo as well.
So with a GCG highflow along with my PFC and intercooler I could run around 225rwkw with standard injectors, fuel pump, and airflow meter? Do the fuel pump and afm become inadequate around the same time as the injectors?
Edited by Lithius
I've actually got that DVD with me. The whole process was seperated into 3 parts. They put in the hi-flowed turbo because it blew when they brought their black R34 to the track. Think it's called HPI-34. In the end, the car was running about 260rwkw? or something around that big power region.
Do not run your stock turbo at 14psi ( 1 bar ) for daily driving. :wave:
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
