What Size Injectors Are R34 Gtts?
Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
By Maharaja Tandoori Cuisine · Posted
Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference! halal food near me -
@GTSBoy @MBS206 I just did some research and watched some videos. I think I know what you mean now. If I can't reach the bolt when the wheels are on, Is it enough if I take off the wheel and jack it up by the lower control arm to add some load instead?
The bloke who built them was having a pull
