G'day guys.
These are from Import Car Parts Plus in the USA.
GB: START 18/07/06 ENDS 10TH/08/06
Im in need of some cam gears and so are 2 mates. These things are so dam expensive for the Jap brands.
What i found was some Arospeed USA RB20/25/26 Cam Gears.
Here's all the info on them - make sure you read all of this cause it'll probably answer all your questions.
These camgears are good for a RB20, RB25, RB26.
To keep the price down, I need to order 10 sets thats 20pcs in total. (Come only in Blue Colour)
How to get onto this great deal"
You can do direct deposit into my account then I'll express post them to you. Both ways are fully tracked so they won't go missing.
Express post cost an extra $10 nation wide.
Cost Price of the cam gears is $170 for the pair, or $85 for 1 pc.
So total cost for a pair will be $170 + $10 postage = $180
This gb will end in about a month or before if we can get the numbers.
Ordering To order a pair, just put a post up here or you can PM or send me an email at [email protected] with your details.
Feel free to ask me any questions.
Also this is a price break i was given if more than 10 pairs are ordered.
10 - 15 pairs $160
15 - 20 pairs $150
20+ $140
Lets hit the 20+ and save!!!!!!
Come on SAU members, im sure we all need camgears and if we can get them for $70 each gear that will be a huge saving.
These are made out of the following material and only come in blue.
RACING ADJUSTABLE CAM GEAR : al7075 forged billet
This is the list we have currently.
1) R33KID *IN
2) 2GU UP *IN
3) R33 STAGEA *IN
4) xRHETTx *KEEN
5) AWDMAT *KEEN
6) JIMx *KEEN
7) Siddr20 *KEEN
8) 180 mph *IN
9) Jaqule *KEEN
10)Tangles *IN
11)Kozeyekan *IN
12)NICKS33 *IN
13)stolen *IN
Edited by r33kid
https://www.sau.com.au/forums/topic/126510-arospeed-adjustable-cam-gears-pair/
  • Replies 219
I'm keen for a pair. And i'd like to see some bigger photos aswell, i couldnt find any details of RB camgears on www.arospeed.com
Some Info i was given from the supplier in the US.
Arospeed announces that it has created a five-bolt design for easy Tru-Time Adjustment.
Arospeed cam gears with an updated design.
Arospeed Adjustable Cam Gears are used by top racing teams across the USA and are a must for engines that are forced induction, high compression and/or utilizing aftermarket competition cams. Our gears enable users to match cam timing with their vehicle's tuning state by advancing or retarding the cam profile in two-degree increments via true laser-etched markings. Precision-cut gear teeth ensure no premature wearing of the belt surface and hard anodizing on the gear teeth is lab-test-proven to be the hardest anodizing process on the market
Key Features:
Increase horsepower and torque without any cam changes, and are ideal for heavily modified engines
CNC-machined from AL7075 billet aluminum
True laser-etched markings on the leading edge of the gear allow for quick, accurate adjustments
Hard anodizing on belt surface is the most durable anodizing on the market
Grade-8, six-point hex bolts stand up to repeated adjustments and feature integral washer flange for greater load distribution
Hope this will answer all your questions.
Edited by r33kid
I'll have to re-check my finances when you do the order, but tentatively put me down for a pair (for RB26, don't think there's a difference?) It doesn't matter what the final cost is, I'm willing to pay the full $180 as long as I can afford it at the time. Thanks!
I could be keen for exhaust cam gear for r33.. So only need one..
When does the group buy end??
Also where are you located??
pickup ok??
Edited by siddr20
pickup ok??
Im located in Sydney, pick up is ok but im quite busy with work, typing this now from work, so its easy for me to express post
1) R33KID *IN
2) 2GU UP *IN
3) R33 STAGEA *IN
4) xRHETTx *KEEN
5) AWDMAT *KEEN
6) JIMx *KEEN
7) Siddr20 *KEEN
We need more ppl so pass the word around.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
