  • Replies 219
well im in sydney!!
I can pickup even on sat or sunday.. or a late night.. Whenever.. i prefer pickup please.. If thats ok with you??
When do you need a final answer??
Cheers
well im in sydney!!
Cheers
Ill let you know when we have the required people and pick up should be fine.
This is the list we have currently.
1) R33KID *IN
2) 2GU UP *IN
3) R33 STAGEA *IN
4) xRHETTx *KEEN
5) AWDMAT *KEEN
6) JIMx *KEEN
7) Siddr20 *KEEN
8) 180 mph *IN
9) Jaqule *KEEN
ARE THE GEARS YOU CAN SUPPLY THE NEW ONES WITH THE 1 DEGREE ADJUSTMENT???
THE PHOTOS OF THE GEARS SAY 2 DEGREE INCREMENTS??
IF THEY ARE 1 DEGREE COUNT ME IN FOR A PAIR FOR RB20
IM IN MELB
IM IN MELB
Each mark = 2 degree increments, i have been told by my tuner that 2 degree is better and easier to tune and you allways get a better result than 1 degree increments!!!
Hope i have answered your question.
Please advise if your in so i can include you.
Arospeed announces that it has created a five-bolt design for easy Tru-Time Adjustment.
Arospeed cam gears with an updated design.
Arospeed Adjustable Cam Gears are used by top racing teams across the USA and are a must for engines that are forced induction, high compression and/or utilizing aftermarket competition cams. Our gears enable users to match cam timing with their vehicle's tuning state by advancing or retarding the cam profile in one-degree increments via true laser-etched markings. Precision-cut gear teeth ensure no premature wearing of the belt surface and hard anodizing on the gear teeth is lab-test-proven to be the hardest anodizing process on the market
YOU STATED HERE ONE DEGREE
are these ok to use with standard cams etc?
what sort of performance benefit can be had buying a complete set for a RB25?
Im definately interested.
Sorry, will edit it, that info might be for there Honda Cam Gears.
Yes these are ok to use with standard cam's, there will be gain in power but it all depends on your setup, and these will have to be dialed in by a tuner who knows RB engines.
Thats fine.
Put me in for one complete set then. $180 delivered to Adelaide. for RB25
cheers. :(
Edited by Tangles
1) R33KID *IN
2) 2GU UP *IN
3) R33 STAGEA *IN
4) xRHETTx *KEEN
5) AWDMAT *KEEN
6) JIMx *KEEN
7) Siddr20 *KEEN
8) 180 mph *IN
9) Jaqule *KEEN
10)Tangles *IN
11)Kozeyekan *IN
12)NICKS33 *IN
Edited by r33kid
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
