  • Replies 219
well im in sydney!!
I can pickup even on sat or sunday.. or a late night.. Whenever.. i prefer pickup please.. If thats ok with you??
When do you need a final answer??
Cheers
well im in sydney!!
Cheers
Ill let you know when we have the required people and pick up should be fine.
This is the list we have currently.
1) R33KID *IN
2) 2GU UP *IN
3) R33 STAGEA *IN
4) xRHETTx *KEEN
5) AWDMAT *KEEN
6) JIMx *KEEN
7) Siddr20 *KEEN
8) 180 mph *IN
9) Jaqule *KEEN
ARE THE GEARS YOU CAN SUPPLY THE NEW ONES WITH THE 1 DEGREE ADJUSTMENT???
THE PHOTOS OF THE GEARS SAY 2 DEGREE INCREMENTS??
IF THEY ARE 1 DEGREE COUNT ME IN FOR A PAIR FOR RB20
IM IN MELB
IM IN MELB
Each mark = 2 degree increments, i have been told by my tuner that 2 degree is better and easier to tune and you allways get a better result than 1 degree increments!!!
Hope i have answered your question.
Please advise if your in so i can include you.
Arospeed announces that it has created a five-bolt design for easy Tru-Time Adjustment.
Arospeed cam gears with an updated design.
Arospeed Adjustable Cam Gears are used by top racing teams across the USA and are a must for engines that are forced induction, high compression and/or utilizing aftermarket competition cams. Our gears enable users to match cam timing with their vehicle's tuning state by advancing or retarding the cam profile in one-degree increments via true laser-etched markings. Precision-cut gear teeth ensure no premature wearing of the belt surface and hard anodizing on the gear teeth is lab-test-proven to be the hardest anodizing process on the market
YOU STATED HERE ONE DEGREE
are these ok to use with standard cams etc?
what sort of performance benefit can be had buying a complete set for a RB25?
Im definately interested.
Sorry, will edit it, that info might be for there Honda Cam Gears.
Yes these are ok to use with standard cam's, there will be gain in power but it all depends on your setup, and these will have to be dialed in by a tuner who knows RB engines.
Thats fine.
Put me in for one complete set then. $180 delivered to Adelaide. for RB25
cheers. :(
Edited by Tangles
1) R33KID *IN
2) 2GU UP *IN
3) R33 STAGEA *IN
4) xRHETTx *KEEN
5) AWDMAT *KEEN
6) JIMx *KEEN
7) Siddr20 *KEEN
8) 180 mph *IN
9) Jaqule *KEEN
10)Tangles *IN
11)Kozeyekan *IN
12)NICKS33 *IN
Edited by r33kid
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
