Well, my front (and rear) bumper needs a respray and i started shopping for quotes. one place gave me a massive $1500 just for the 2. now the main gripe i have is they told me i need to replace the chrome strips that go around the bumpers. i thought these could just unclip/detach and then go back in later. she was adamant that i couldn't do that and she was going to source some new ones for me. i don't know if they're trying to stitch me or these bumpers actually need to have the chrome replaced.
if anyone has had the same thing happen or has repainted the stock bumpers could you let me know how you went about it?
https://www.sau.com.au/forums/topic/126523-repainting-stock-bumper/
try to get a few qoutes from a good panel beaters around your area. Normally panel beater that have good cars (Bms, mercs ETC) will be a good indication or those used by the dealers(Bmws, mercs ETC)
Offer them a cash job which will be much cheaper. My panel charge me for a fender $300 the last time i did respraying. Dont forget though they have to take off the bumpers that might add abit on the labor. But then if you a skill full enough take it off yourself to save abit on the labor
my panel beater fixed/repaired a fibreglass front bar and resprayed both the front and rear bars on my celsior for $450.
he also resprayed the rear bar of a camry that i tapped for $150
i would expect him to charge about $200-300 max for a front bar spray only.
We just recently resprayed my car and we removed all the strips to do so.
They are held on by a really good (not dodgy) double sided tape.
They were fine to remove and then re-stick.
We didn't get around to doin my bumpers but thats another job for another weekend.
But my other half says that they should be the same as the rest of the car.
Have you considered doin the bumpers yourself?
Might be a cheaper alternative if you buy the paint and do it yourself..
I was quoted around $400 to repair a crack (sizeable) on right corner of rear bumper bar, clean for painting, and repaint in silky snow pearl using paint that I will supply. Quote included for removal and refit of the rear bar....... I havent taken it up as yet.
Hey Terminal, who did you see for your quote/s?
so far i've only received a quote from the belconnen auto refinishers just around the corner from you near sportsmans warehouse. can you shed some light on someone else in belco who won't ask for my first born?
Is it difficult getting matching Stag colours if you want to DIY?
yes it would be very difficult to get the color matched up even by the panel beater. They use a computer color codes to mic the paint up. They cross reference it with the nissan colors. If they didnt get it right your car will ooklike its got a lighter tan on the newly painted section. or more tan.
So its best to get a panel beater that uses computer color mixer and of course oven baked and fresh :dry: .
If you want to DIY i suggest you remove the section that you want and just let them paint it.
Did they say anything about having to replace the chrome strips along the bumper? that's why mine was so high, they said i had to replace them, they couldn't just put them back on after the painting
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
