Since toying with the idea of putting a supercharger on the RB20 went down in flames (Read: Cost) I'm currently looking into turbo upgrades, and I was recently talking to Tom from www.bd4s.com.au.
I was enquiring as to the price of their HKS GT2530KAI units. He wrote me back telling me that the HKS GT-RS is a better turbo. He claims that it will spool faster than the 2530 and also make more power through the range.
I looked at the HKSUsa website and it appears that the GT-RS and the 2530 both have the same exhaust housing and wheel specs, but the GT-RS has a larger compressor side, does this mean, as Tom is saying, it will spool faster and make more power through the range than the 2530?
Another thing I am concerned over is the fact that HKSUsa only list the GT-RS as being supplied with a T25 flange, I was under the impression that for a unit to be bolt-on for the RB engines, it required a T3 flange?
Any insight would be greatly appreciated, as well as any experienced people have had with either of these units, especially on the RB20.
Cheers,
Ben.
https://www.sau.com.au/forums/topic/126524-hks-turbo-comparison/
The 2530KAI is little modified from the previous 2530, other than a ported shroud comp housing. Specs of the rotating assembly is unchanged. Response ability should be unchanged. Normally the porting is done to control/reduce surge.
The GT-RS has an upsized comp impeller 71mm vs 60mm for the 2530KAI. This will directly affect (reduce) its ability to respond quickly, but increase its power potential compared to the KAI.
Hope this helps.
cheers
Dale
Search HKS Japan , click first site and look at the menue on the LHS of page . Click on Turbo , GT-RS and scroll down through the S13 (SR20 version) , R34 GTR version to RB20/25 version . Even shows bling pic of port shrouded comp cover .
Enjoy .
Edited by discopotato03
Hope this helps.
cheers
Dale
So it is in fact true that the 2530KAI will spool faster than the GT-RS, but it's due to less rotating mass, if I understand what you're saying correctly?
Sounds like for both purposes (Price and response) the 2530KAI is deffinately my best choice.
Infomation has helped alot, thanks all :D
Ben.
