Thinking of buying my 1st car soon and was looking into the Skyline market instead of the Civic market ..
Noticed the R33, non-turbo automatic which are usually a good price (10k - 16k) :D
Just letting everyone know, only want one for looks - not for racing etc .. lol :D
So turbo, manual etc isnt really an issue for me .. Any opinions for buying one for my 1st car?
Oh and im 17 btw :D
https://www.sau.com.au/forums/topic/126534-r33-n00b/
Yeah I'd found them for 10-15k on carsales and some were modified (looks) quite nicely and some with low kms too .. is there anything wrong with having one? My friend said they're heaps heavy & go slow etc .. obviously hasnt put me off lol :D
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2335976
Oh and im 17 btw :D
as i know turbo/non turbo or manual/automatic cost the same, for R33 GTS25t u would pay the same like for the non turbo.
so u dun't need 2 use ure car 4 races but u can have a LOT of fun with it and if u want it 4 show, its better with turbo 'coz if u go down from the gas ure bov makes pretty sounds =D
i would recomment R33 GTS25t and could also recomment a good importer if u like
had have a R33GTS25t automatic for 2000 USD but had have 160 000Km condition was ok, clean interior
Edited by FLYSKY1
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2336015
I think I'll have it for 3-4years just until I have my full license, and I agree that turbo would be good for show too but you arent aloud to have turbo on your L's or P's in New South Wales ;)
Oh and just for the record, after one exactly or similar to this:
Edited by iamvinhy
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2336086
17 years old? Go the NA. Expect to pay around 14k (give or take 1K/1.5K). The NA will be good to get practice on - jumping straight onto a turbo might be fatal if your not careful. Shop around - or look at the importers like allblitz, jspec etc. And post up pics when you do get one ;)
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2336100
Guest IH8VEE8S
ok look here....
if you want a turbo and end up getting an NA, you will regret it! trust me on that 1
i bought a 93 R33 GTS4 auto not too long ago in very good condition and low Ks, only ended up costing me 7.5grand all up ;) but it was off a family friend so that helped a bit lol.
i do regret getting it though coz i started off with a wrx lol and well.....theres a huge difference between em. but since its your first car then go for a NA R33, still get the looks, comfort, etc ;)
best of luck with whatever you get ;)
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2336127
17 years old? Go the NA. Expect to pay around 14k (give or take 1K/1.5K). The NA will be good to get practice on - jumping straight onto a turbo might be fatal if your not careful. Shop around - or look at the importers like allblitz, jspec etc. And post up pics when you do get one :blink:
Bump! your an idiot if u get a turbo when ur under 20 yo anyway.
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2341115
lol wtf
i tried to make sense of what you wrote....didnt have much luck
you think non turbo/turbo and auto/manual cost the same? LOL :devil:
and
"ts better with turbo 'coz if u go down from the gas ure bov makes pretty sounds"
:w00t:
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2342173
u calling me an idiot?
so like you hit 20 and you fully know how to handle a turbo car. lol. ok. sure.
but then again... you are special :(
seriously, statistics show and prove every year, more teenagers lose control of high powered cars than any other age bracket.
if not having a turbo car cuts the death rate by 70%+ then there shouldnt be 18-20 yos driving turbos... simple.
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2342733
I agree with freddy on the R33 GTS4 quite unique . Although extremely heavy and slow, not good for skids if you are bit of a terry. But otherwise should be able to find a n/a r33 for under $10K.
I think the GTS4's come with 5 stud hubs too, another benefit if you are looking for wheels.
Edited by siiick
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2344230
IH8VEE8S' 33 GTS4 auto has 4 studs...
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2344304
Guest IH8VEE8S
nope, GTS4s have 4 studs aswell :
https://www.sau.com.au/forums/topic/126534-r33-n00b/#findComment-2346816
