Questions About Nengun
frankxinyu
 Share
very true.... my power fc should be all right then. thanx guys!!
btw, where can i get a custom broker?? are they listed somewhere?
When i brought my GRT into the country I used Mac Customs - 07 3868 1590. Fax 07 3268 2191. I never had a drama with them with my car. Try them and see if they will do smaller items.
I can clear it for you should you need help. I am a customs broker... pm me if you need some advice.
It should sail though customs as long as the free on board value is under $1000
Even if it was over $1000, an ECU is duty free anyway - you'll still be up for gst and associated entry charges though.
Cheers.
Cheers.
cheers mate, one more thing, what about exhaust dump pipes which was just under 1000 without delivery?? should they be tax free as well??
appreciate your help.
Dump pipes/exhaust systems are dutiable (10%)... Make sure you don't get confused between tax and duty though. Duty is a revenue and GST is... well... a tax.
GST is calculated on:
The value of the goods
+ the cost of overseas transport
+ the insurance (allow .25 % of the cost and freight usually)
+ duty applicable
Of course if the value is under $1000, then the above is irrelevant - always good to know though so you don't get any nasty suprises.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
