Hey ppls.
For a little while now, I have been populating an XL Spreadsheet of Dyno Figures to compare my tunes and modifications.
I got the idea off Cubes, so I can't take credit for the idea itself.
BUT.
I'm going to open up my little spreadsheet to everyone to play with and add their numbers too.
Maybe we could even prepare a HUGE one to compate all sorts of fun and wonderful things.
Anywhoo.
Attached is my spreadsheet with graphing, and you could perhaps add to it, or cut and paste it, or add your own numbers too and have play.
BASS OUT
Power_Curve_XL_Sheet.zip
https://www.sau.com.au/forums/topic/126563-power-figures-dyno-chart/
  • Replies 101
top work bass but i think it should be plotted into mysql with a php site so it can be customised and comparison at the click of a button. that excel sheet will suck when 5 other people add their results. like the v8 one you found, that was tops. we need that
I have done a remake of the sheet. It will require the re-entering of the figures unfortunately, but I have made a couple of changes.
I have changed the speed scale from 3's to 2's.
More notably, I have set up the graph to display only 5 figures at a time. I have added a Rank function (row 2) so you just enter in the numbers 1 to 5 above the figures you want the graph to display, then press the "Sort by Rank" button. The figures will be sorted and the graph will display the results you wanted.
Or you can sort by Max power, I have added a Max Power row at the bottom of the table, you can sort to show the 5 most powerful cars on the graph.
Hopefully this will be a little more user-friendly and a bit easier to read. I can always change the graph to read more than 5 if need be, but having the graph limited to a specific number of records, rather than all of them being shown at once will keep things a bit tidier.
I hope this helps.
Power_Comparison.zip
Needs to be RPM based not KPH
will be more accurate as kph, not rpm, as most people will only be guesstimating rpm. not many dyno sheets have rpm up the side to base it of, and if i go out on the road and say that i get 100kmh at 2850 rpm, that doesn't take into account both my speedo and tacho being out.
Edited by mad082
To save the hassle of re-entering all the figures, I made the changes to the original sheet.
The graph is now on a separate tab, and will display only the first 5 records. Enter the number 1 to 5 of the records you want to see, and press Sort by Rank to have those 5 appear on the graph. I added a Max power field, and a sort macro to sort by max power so show the top 5 most powerful cars.
Added RPM to the graph instead of speed. I used the formula to work out the RPM for the speeds we were using, rather than reworking the speed for a given RPM because that would require re-entering all the power figures.
  • 3 months later...
just curious, on the graph 102km/h is lined up with 3643rpm...on my dyno graph the rpm's dont line up with the graph 102km/h=3849rpm
what can be possible answers to this...as far as i know ratios are stock ( i havent changed them) would it be my rims? 19s?
just makin sure ay
cheers...ben.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
