Ah okay, here's my numbers if someone could add them in. They start at 60km/hr and go through to 183km/hr. Also I really like the idea of PHP/SQL page, would be awesome to be able to compare so many different cars/modifications at the click of a button.
55 63 73 85 87 90 95 98 103 106 110 114 120 127 129 138 147 151 163 167 173 180 190 197 198 199 201 201 202 202 202 203 204 204 204 203 197 195 193 192 190 181
  • Replies 101
Is it possible to make it so that you can enter either road speed or rpm? I have a dyno sheet that is neatly broken up into 500rpm major and 100rpm minor increments which makes it easy but most people have ones that have road speed.
Here's a spreadsheet that will calculate speed based on rpm or rpm based on speed. You will need to know your tyre size, gear used, ratio for that gear and final drive. You can change the series of rpms or speeds to suit.
The example is using a R34 GTR in 5th gear for the rpm series used in the power spreadsheet.
It would be interesting to see how accurate the speed calculation is as it is theoretical and doesn't take into account real world conditions.
speed_rpm_calc.zip
It'd be good if the whole idea was comparing apples with apples.
I know its hard to do, but to compare the performance of a GT30R with a HKS 2835proS [as examples] would be a good thing. But to do this you need [ideally] two cars exactly the same or one car using both systems. This will never normally happen.
I know at the moment there are only a few results posted, but what happens when you get 20-50 results, the graph would be flooded.
To overcome this situation, maybe the whole exercise needs to be split up into stages of performance development.
More complex, but better definition.
I'm definitely interested too, I think it's a great idea that will end up getting a lot of use, especially as the number of cars added into it grow. It will also save a lot of people from posting threads asking about what sort of power they can expect from specific mods/turbos etc.
Will also allow people to have four or five of their own graphs to compare against each other.
you would be able to pick up to say 10 graphs and they display.
Could sort via highest, best average between 4500 and 7500 etc. etc.
Stop talking and get on with it..............lol. Sounds very good to me, it will be interesting to see what makes power and where they make it.
BTW I'll bring my dyno chart in tomorrow and provide some some figures.
I haven't mentioned my daily rate yet ;)
Ok, this is a spare time project so don't expect results yesterday. And while I will listen to suggestions don't expect miracles.
The first phase will consist of:
- a database to store car, rpm (any rpms should work and not specifically those in the spreadsheet), power at each rpm(kw), engine type, turbo type, and a description field to outline mods.
- a php page with a list of cars
- a graph page showing output for the selected cars
- possibly a page to add your own data (if this gets abused I will pull the site)
Once this is done I will start looking at extras/wishlists.
And if someone else is going to build the same thing speak now and I won't bother, as I can't be assed with duplicate effort.
Now we have the rules, I'll start building. :)
Rules sound good.
We need also to have the graph work on kph as well as RPM and should be either.
The problem with just RPM is that a lot of charts are in kph. Also different wheel sizes and stuff will effect rpm but not speed.
A lot of dyno operators are now printing out logs of the dyno run every 2kph. See attached.
Thanks heaps for taking this on man. its really tops!
Wow that was quick. I did start a page before with car, engine, mods, comments etc that people could enter their data into. Then they could search/view the list of cars in the database and select the tickboxes for the cars they would like to see on the graph... That was the idea. I have only done the page which drops the info into the database. Sounds like you got this under control Willo, but shoot me a PM if you want help anywhere.
This would be very easy to implement a login using SAu forum name and password to keep it locked down to memebers only, however that will need access to the DB to check the encrypted password against...
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
