  • Replies 48
Stupid question again.. How do i reset my ECU
Disconnect positive battery terminal for 20 mins...
Note - you will lose your head unit settings too - radio stations, and audio controls will be reset to defaults..
how many big horsepower turbo cars do you see running heatsheilds? very few. most of them don't even have cold air feeds.
How many big horsepower cars do you see running bonnets?
Having a colder intake will ALWAYS help power.
Even if its only 5 degrees cooler out of the turbo its still means your turbo is cooler, your intercooler has to disapate less heat and the air entering your engine will be cooler.
How is that not worth the small effort to make a heat shield?
i'm not talking about dyno runs. i'm talking at the drags.
and the problem with most heatsheilds is that they reduce the amount of air that can get to the pod. so if the pod can't breath as well you will lose power, not gain it.
all so i want to get something to keep it from moving atm its just sitting there what can i get made for it??
Bunnings sell "Make a Bracket" stuff. It's a dollar for a 1M piece and you can make bends in once very 5 cm.
My experince with a heathshield is positive. On my first track day I went out with an un-shielded pod. After my 3rd run the car was gurgling like a bitch every time I back off the throttle amd throttle response was lost. I also had trouble starting the car all aftermoon.
Afterwood I purchased a CAI box from "mr Crust" which uses the factory snorkel to direct the cold air into the box. Been on two track days since and have not had ANY gurgling issues which has resulted in a more consitent car all day no matter what the temp is.
probe was jammed in to the pod.
Basically it was sitting in front of the AFM mesh just like the afm probe sits in the afm.
Don’t go around giving advice on things when you are going by your own minds theory.
And don’t compare the majority of skyline owners to 2000hp drag cars.
Most people on here have street cars which they occasionally take to the drags or tracks.
mad082... i fail to see how having a partition (like what i have in my car) between the engine bay and the pod is restricting the airflow?
my pod has space 360 degrees around it, and a clear pathway straight to the cold air coming in around the headlight.
you can notice the difference with the partition there... without it there, you go for a hard drive, and then touch the pod - its warm/hot...
with the partition in place if you do the same thing, the pod is cold, often very much so.
the partition is stopping the radiated heat from the engine bay (and intercooler pipes, as i'm using modified standard cooler pipes)
I hope so for him anyway.
But generally when you bang a piece of electrical equipment as you drive around, electrical components will take the full force of it, ie: solder will come off.
My car is a 96 model in a mint condition, has done not even 50 000 KMs... (interior and exterior are immaculate) I hardly think that for some reason AFM wanted to cack it... the flapping pod caused it.
Ive learned my lesson and all in all it cost me over 250 bucks to fix it... f**ken waste of money dude.
Well for the record mine is a 97 model 33 with Genuine log booked k's and mine hasnt done it. Anything electrical can go at anytime thats the nature or electronics especially AFM's they are very touchy.
My mate has a 1989 Laurel and his HKS mushroom isnt secured and never has been and he drives the thing hard and drifts it and his AFM hasnt died on him. I just think its a big call blaiming a pod filter as the main reason for your problems
Chris
Edited by alphanumeric
AzzurrA, is your partition on the side of the pod ? or is it covering the top too?
Wondering if you'd still get heat from the top. I havent made a box for my pod yet, just investigating it now.
there is very little power loss due to sucking hot air. the pod is sucking more air than the standard air filter so that increases power. you are better off having no heatsheild, as a heat sheild can reduce the amount of air the pod is sucking. heatsheilds make bigger power differences on natro cars, but very little difference on turbo cars as the air is heated the moment it goes through the turbo. and is then cooled by the intercooler, which is where power is lost or gained.
I dont agree - from my personal experience.
Rb25det, K&N pod filter...... open engine bay, sucks hot air.... was all good
added a heat shield eclosure (side and lid), didnt really change anything.
But then I took that off and added Maxx's CAI enclosure - now the car is sucking in so much cold air, my tune on the SAFC & SITC is now out, using 20% more fuel per tank, etc etc. With a retune I could regain that 20% fuel per tank and go from 160awkw to mid-160's.
Sucking in pure cold air with no hot engine bay air will result in a HP gain.
it isn't about how big the partition is, it is about how much air can get in.
for example if at 5000rpm the engine is sucking in 700cfm, and you partitioned airbox can only let in 500cfm then you are going to have less power than someone that has no partition and can feed up to 1000cfm.
and if cold air was so important and made such a difference, wouldn't the big hp cars be using it? since they are chasing every tiniest little bit of power they can get. if it can make a slight difference on a road car, then it should make a huge difference to them.
I cant argue against my fuel gauge!
simpe as that
Maxx's cai box utilises the standard snorkel, getting far supirior flows of air then what I was previously. Its cold air now, and tune is now off because of it. Its getting so much cold air now on boost that the ecu's are throwing in extra fuel to compensate.
when I pay $100-odd for a quick retune I sincerely expect a 5awkw gain from the tune.
you keep going back to the point of 'big hp cars'
which cars are you referring to exactly?
if you're referring to big hp drag cars.... you'll find that alot of them either remove their lefthand headlight, or have replaced it with a custom headlight that incorporates an air intake. With drags, the car is only started a very short time before the actual run, therefore they don't have to worry too much about heat soak and the ambient temperature of the engine bay... and as i said, during their run they're getting outside air forced through their engine bay anyway...
and yes, alot of them still run some form of shield anyway.
if you're referring to big hp circuit cars, you've got to be kidding me... i don't think i've ever seen one that DOESN'T have some form of heat shield!?!
I made one myself too, its not enclosed, just a partition. Go bunnings lol
Just need an aluminium sheet and cutters. Use cardboard first to make a mock up and use that as a template.
For the CAI, get a flexible pipe from supercheap and feed it from the front bar. Get a pipe that is not ridged on the inside for smoother airflow.
How much did this cost you and where is "Mr Crust'' i think this is what im after.
$120.00.
Pm "mr Crust" but im pretty sure he's sold out
http://www.skylinesaustralia.com/forums/in...amp;hl=mr+crust
dude....
they arent wrapping the pod in a metal blanket... sperating the pod from the main heat sources of the engine bay is not going to make a significant restriction to inlet flow as long as there are suitable places to draw fresh air from.
I myself have seen more consistent performance from my car with the adition of a heat shield, and im not going to sit here and believe anyone who says it makes the car run WORSE. maybe you should give it a go yourself?
but i am yet to see a dyno sheet proving the difference. and it would have to be done back to back (run first run, pop the bonnet and put on the partition, then do the second run).
A dyno is unable to simulate road conditions. So you wont, or shouldn't as the findings will be flawed.
Depending on the power level a pod isn't required, do remember turbos don't experience the same loss of power as an N/A due to an inlet restriction. I believe SK has also stated this in a previous similiar discussion.
The better flowing pod will make very little if any difference to power levels, providing we are talking sensible street usable power levels, not 800hp through a stock airbox. :)
Therefor 'I' conclude, A pod for street sensible power levels only has negative affects on performance...
1. The inlet air temperature is higher, resulting in a higher actual outlet temperature
2. The higher actual outlet temperature will heat soak the ic quicker
3. The air entering the motor is going to be higher, hotter air is less dense and promotes detonation. Both of which will reduce reliability and power, I forget how much power is reduced by every degree air temp is raised. But there is a real power loss.
I believe it is 1% power for every 4deg C.
I'd still be very interested in seeing a test like I described on the first page, actual temps @ throttle body.
An IC will heatsoak faster with higher temps, but the car is usually travelling fast when on boost, and temps will plateau at a certain point (which will be slightly higher with higher intake temps).
I agree that a partition will lower temps, but I think people overestimate the benefits "on the street" on a FMIC'd turbo car.
If going for a pod, I would at the very least have a cold air feed directed at the pod (which is exactly my setup).
Fixxxer
    • Any difference in induction noise?
    • If I got a dollar for every flipped commuter missile I've driven past I'd have two dollars   Some people get into wild adventures on the road and I doubt it's gender or ethnicity specific. I'm just glad I don't usually drive during peak times.
    • Just got the car back and gave it a good run back home Power wise, whilst it only made a extra 5 killerwasps up top at 7200 rpm, it made more power everywhere from 2500 rpm and kept pulling much harder all the way, to the point of me relearning when to shift so I don't hit the 7200 limiter, with the old intake it seemed to take alot more time to rev out, and, throttle response is also much improved  As I didn't want to remove the bumper every time I serviced the air filter (basically every aftermarket and fabricated CAI has the filter behind the bumper) it currently has a hektic exposed pod in the engine bay sucking in hot air, this will be rectified shortly after some some of my CAD (cardboard assisted design) for a alloy heat shield feed by the OEM intake tube behind the bumper, this will cop some wrinkle black paint, as well as the intake pipe for that totally OEM look... The only fly in the ointment was that the OEM "strut" brace doesn't fit over the rear runner of the new intake with the 2.5 engine is in the engine bay, as the 2.5 raises the engine up by 20mm, it's not a war stopper, and I didn't notice any difference without it in some twisties, but....... MX5 Mania is bringing in some GWR "fancy pants" braces that apparently do fit, if it bolts up I'll grab it, it is also stiffer than the OEM one, which is a bonus All in all I'm happy with the outcome      Fancy pants "strut" brace that gives the required clearance      This is where the clearance issue was, the GWR extends out past this
    • Well, I'm back from the dyno today. Some things do partially make sense. The pod filter/airbox delete picked up between 6-10rwkw on 98 - because heat soak does kind of affect things and there was playing with tune/timing/AFR. Oddly enough, the car was running much leaner than before. So lean it was audibly pinging on the dyno which I got video of:   70de0dd5-2099-4a71-8b10-6fc833fb9d59.mp4   We're talking going from ~12.7 in the past to the first run being at like ~14.0. It is now tuned to ~12.5 on the Dyno, which correlates to about ~12.1 on my wideband in the car. These matched last time, which is very odd. The dyno plots only show the dyno's reported AFR - should be last time, yet now it no longer agrees and was way leaner. Nobody has an explanation for how a pod can make the car run notably leaner, yet not really give any more power when you add fuel in. A few different types of intake design were tested:   94c22c34-7991-4902-af85-314b5f5bf352.mp4   There was no difference other than IAT with the pod sticking out of the bay. The pod sticking out of the bay (but connected) is actually still warmer than what I usually see on the road. Removing the pod entirely lost about ~2kw. But to be fair, all of the runs could be argued to vary by that amount when temperatures climb etc etc. It's safe to say that the filter isn't causing any restrictions of any note that can be reasonably altered in any way. This is in line with what I'd expect given the Engine Masters testing. 323KW on 98 and ~335KW on E85 is actually a pretty solid result, up about ~45kw from 99% of LS1 cammed combos, with generally much larger cams/exhaust etc as well. It is after all up 42KW (98) and 54KW (E85) from before. +10KW from a pod and removing the box is cheap as chips compared to what the head work cost per kw No, I did not get to drop the exhaust and test. When it comes to exhaust... it all just seems to change frequencies and cost or gain 2hp here or there. I don't realistically think I'll drop this to test it - because there's not much else I can really do about it/route it any other way/make it bigger/just bought mufflers. Engine masters beat the hell out of headers with a hammer to deliberately kink them and didn't lose power at all, I sincerely doubt that going larger primaries would help. If it were even possible for clearance/conversion reasons... which it's not... I may throw the E85 in there at some point and do a drag run to see what MPH it traps for science. It isn't lost on me that ~320kw Skylines do trap about the same MPH that ~370kw F-Body/Corvettes do in the USA for the same  or similar weight. (122-125mph). Of course, if I go there and trap 104mph or something then I'll just 'accidentally' have an accident on the way home from the drag strip and buy a M4.
