Just had a thought,
GTR fenders, whatever bonnet. grill, bar and rims you wanted. Added cost of spraying and fitting = ~$7-8000. Maybe more, I'm no expert on costs.
Sell your GTSt + at least $8000 = GTR. Its win win, plus you get an RB26, 2 turbos, 4WD, 4WS, GTR seats and a GTR badge :(:P
  • Replies 99
Just had a thought,
One question champ.... Why? He's building a drag car - what you've suggested would make total and complete sense were it to be a road car but it isn't. GTR's are VERY heavy, harder and more expensive to make quick for drag racing and a waste of money for this application. Did I mention how heavy they are?
BezerkR32 already has the RB26 but it's not going on an RB26 block, doesn't wan't 4WD for the reasons stated above and 4WS? Not many corners on a drag strip :O
GTR badges are important though!
Adrian
little bit late know, guards werent as expensive as you think, and not really keen on two turbos, Gtr are the most fun on the street but its not really what i need for the track. besides, just stuck this in. also trying to keep car around 2500 pounds (1130kg) big ask in a gtr or 33 whale.
Just had a thought,
Edited by BezerkR32
Just had a thought,
Sell your GTSt + at least $8000 = GTR. Its win win, plus you get an RB26, 2 turbos, 4WD, 4WS, GTR seats and a GTR badge :(:O
Not everyone wants an overweight 1500+kg car, or a small 2.6lt motor :P
I'm the f**king juggernaut, bitch! :(
As djr says, why not buy aftermarket cosmetics? Carbon fibre is lighter and stronger than aluminium ya know.
Hey 28" rims, nice :P
I find aftermarket cosmetics do not offer the quality factory parts do, alos there is hardly a wide range of parts for r32s. Unless you want the some cheap fiberglass kit with a poor finish.
Also carbon fiber is dick all lighter and harldy legal anyways.
It's nicer to have Jedi powers.
Bye bye, Michael.
r u jedi or sith?
jedi use their powers for Good purposes, not evil ! :sorcerer:
Bezerkr,
go the GTR guards - get the rear end pumped out. fit big grippy tyres, run 9s
have fun doing so too.
btw: Dont test out that roll cage, ok? Might look silly on a 400m straight strecth of road, lol !
Sounds good, can you get me one for under $400?
How about the front bar from the gts4? I dont know if they all have one, mine does and it has a large front opening, looks good, is factory and not a gtr...
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
