Just found out something curious
Officially, stageas have less power at the flywheel stock than R33's.
Skyline http://english.auto.vl.ru/catalog/nissan/s...e/1996_1/21671/
vs
Stagea http://english.auto.vl.ru/catalog/nissan/s...a/1997_8/21850/
Why the hell did they detune the stagea when its 300kg heavier!
https://www.sau.com.au/forums/topic/126625-stagea-vs-skyline-std-power-figures/
Nissan decided that the S1 auto gearbox needed some protection from the heavier weight
The manual (S2) Stageas have the same power as (R34GTT) Skylines
But what about S2 autos and R34GTT autos?
:D cheers :D
Edited by Sydneykid
Somewhere in Skylines there is a comparison of a Stagea, (S1 or S2 I dont know) and two or three other FI cars. The Stagea did better than some. Perhaps someone (SK) knows what thread.
According to this: http://english.auto.vl.ru/catalog/nissan/s...a/2000_6/21829/
The S2 Auto and Manual both have 280ps, which doesn't surprise me too much.
I was under the impression Stagea rb25det runs a little less boost that R33 versions. Like 6-7psi Stagea, 8psi Skyline. Although that would imply different ECU maps, otherwise, based on Stagea AF's, the Skyline would be too rich.
It's just a different calibration to protect the auto. The autos break! Heaps of cars are detuned for the auto variants. The Stagea is detuned a bit more than the skyline auto because it id heavier and AWD.
yea true the detune it cos their auto gearbox cant take it. This is also true for an Rx8 an uto the rev limit is at 7k where the manuak goes to 9.5k rpm.
well, i really dont think 10kw difference will kill an auto box....
but hey, we've all worked out an extra 60-70kw can :cheers:
More likely the 20 nm of extra torque
Regarding boost, our Stagea came with 4 psi / 6psi (high / low)
The R33GTST came to us with 5.5 psi / 7.5 psi (high / low)
So my guess is the extra 1.5 psi of boost accounts for the torque difference.
Auto ECU’s and manual ECUs in R33GTST’s are definitely different.
When I swap the turbo on the Stagea, I will check the wastegate actuator spring pressure. If my guess is correct, the Stagea wastegate spring should be ~1.5 psi lower than the R33GTST spring.
:ban: cheers ;)
I always thought this was just down to slightly different configuration between the two cars.
To use another example, look at where the VQ35DE engine is used, its in like 5 different nissan cars (probably more), including the 350Z, stagea M35, maxima, skyline v35, patrol?, and there are sure to be others I've missed.
In all of these cars the power figures differ - either in kw or torque or both.
I figured it was just that the setup is configured differently depending on the purpose or the target market of the car.
Sounds like the same theory diesel engine manufacturers have.
Most common rail deisels will produce a difference of up to 200 HP from the same motor simply by programming the ECU. You simply tell them what you want the motor to do and they'll program it for you.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
