Needed a roof rack in a hurry.
Used some 25mm OD pipe, Cyclone scaffold tees, 25mm ID clear plastic tube, black paint and duct tape.
The horizontal section of the tees needed flattening a bit to more nearly be the shape of the rails.Pipe was cut 920 for back, and 945 front. They are different, and the front was cut a bit short so it can be moved back to the centre of the rails. Metal parts were sprayed matt black and the tube was slit along its length to make it easier. Duct tape was wrapped around the hose, and also around rails where tees were clamped.
After using I had to move the front cross piece back to the centre because of wind noise.
Total cost if buying all the bits, about $20.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/126638-roof-rack/
just for interest's sake,toyota rav 4 roof racks are a straight bolt on for stageas. I run a pair of ex-warranty rav racks on my S2.
new from toyota they're about $280 a pair.
Justin...
I used my Subaru Racks, $350. Big difference $20. They do the same thing. lol
https://www.sau.com.au/forums/topic/126638-roof-rack/#findComment-2338641
it IS a big difference,providing you actually pay it. I got my rav racks for free,out of the warranty bin at clean up time. I have a heap of roof rack parts at home,including some rx330 aero racks. will try those on at some point as well. if they work,someone can have my rav racks if they need a set.
Justin...
Edited by fergo308
https://www.sau.com.au/forums/topic/126638-roof-rack/#findComment-2339114
Nice work there Hugh! So when are you going to start making them enmasse and sell them on SAu in a group buy for $50? ;)
That is what is the rage lately, I am still trying to find out what I can setup a Group Buy for :cheers:
And damn, you really dont have any sunroofs, bummer :ban:
https://www.sau.com.au/forums/topic/126638-roof-rack/#findComment-2339141
i can imagine what that will do for your highway fuel consumption. i think i'll be going for a more aerodynamically designed one.
Even with my ex Subaru and Skyline racks I always had to move them back a bit from the front.
As I've said elsewhere, " if you can't afford the petrol,you can't afford a Stagea".
Anyway, racks are not usually an everyday use. The bars take 5 mins to remove. The whole idea was to make something pronto.
As far as agroup buy, The only tools needed are a hacksaw (or angle grinder) to cut the pipe, a 10mm open ender and a Stanley knife, so it is very easy to make. Not really worth the postage.
https://www.sau.com.au/forums/topic/126638-roof-rack/#findComment-2339593
  • 4 years later...
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
