I am currently stripping 4door R34 it has no motor gearbox or motor ,headlights etc..
So here are some bits any other questions call me on 0412426573
Bonnett $450
Complete set of brakes $800
standard struts $400
standard seats $450
diff $300
Passenger guard $200
front bumper $200
Triple guages cover $100
Doors make me an offer
car is still rolling if anyone wants the lot...Radiator support has been cut out.
If you want something please specify what it is i am already getting emails asking to list everything i have that would take for ever..Best to call me if you are serious i have been stuffed around so much on here..Thanks
Edited by braddo1600
https://www.sau.com.au/forums/topic/126646-some-r34-parts/
Bonnett $450
standard seats $450
diff $300
front bumper $200
DO you have factory exhaust? how much$$$?
https://www.sau.com.au/forums/topic/126646-some-r34-parts/#findComment-2338541
Location?
Radiator and Shroud?
Just Shroud?
Sorry i don't have the radiator or the shroud...
I don't have the exhaust either sorry....
I am striping this as i bought it uncomplienced and only needed the motor and wiring loom...
https://www.sau.com.au/forums/topic/126646-some-r34-parts/#findComment-2350071
