I just finished the job last night, once I remembered to grab my caulking gun!
Things you will need:
* Black windscreen sealant - costs around $10 from superCheapAuto.
* A caulking gun
* Thick rubber gardening gloves
* A ratchet and/or spanner - 10mm
* A philips-head screwdriver
1) You need to remove the trim that covers the rear inner of the boot. Use the philips-head screwdriver to unscrew and back the clips off, and then they just pop out by hand. Next, there are 5x 10mm nuts holding the tail-light assembly onto the body, which are accessible from the inside of the boot where you removed the trim.
2) There are also 4x 10mm nuts holding the Skyline panel on. On my car, it had to come off for the tail light to start moving out. As you can see, the tail-light has a little strip that sits behind the Skyline panel. You may need that spanner to get to the nuts on the right-hand side. I did, but that's also where my remote boot-release solanoid is.
3) With gentle, but firm pushing, the tail-light should start to come out without the aid of a hairdryer. I tried the hairdryer, but it made no difference. I pushed mainly on the threads that the nuts were on, using a small piece of wood so that I didn't puncture my hand.
4) Don't forget to unplug the wiring harness before you completely remove the tail-light assembly. It's just the one white plug. As you pull the assembly all the way out, take care that all that black sticky stuff doesn't get stretched like cheese on a pizza, as it will probably stick to your rear bar and be VERY difficult to remove. The old black sealant gets seperated between your tail-light and the body of the car. I don't know what a paid professional would do, but I took to removing ALL the old stuff.
5) 2 hours later, it's all gone. It took another hour to get it off my hands. I tried turps, metho, acetone... eventually I cracked the shytes and poured mower fuel over my hands. Instant dissolve! I now recommend the use of thick rubber gardening gloves instead of bare hands. Scrape a chunk of the sealant off, roll it into a ball, then dab and rip it off the remaining sealant. If you do it bit-by-bit, eventually the rest of it will follow. Don't experiment with solvents or anything like that on your paint. Ever.
6) The tail-light cleaned up nicely too. Check for any obvious cracks in it, as water could get in there, then out one of the breather holes in the rear of the assembly. Now is a good time to unscrew the globes and clean the contacts, and to blow a hairdryer into the sockets to get the water and moisture out.
7) This is where I ran the new stuff with the caulking gun. Notice I went around the top middle and bottom middle threads... The water from the boot gallery goes down over the top-middle thread, so I figured it's not a bad idea to divert the water away from this, as I think that's where some of the water was coming from. Additional to this, I put a TINY bit on each threaded rod, just incase water was getting in that way. When using the caulking gun, and the tube of sealant, I did it without the screw-on tip that comes with most tubes of stuff, simply because the tube itself gave a much thicker flow of sealant. One trip round the whole assembly at a slow pace did the job nicely.
The new sealant is not as sticky or adhesive as the old stuff was, so I also used one finger to press it down to completely fill the little channel where it is supposed to go. This should tell you whether you have applied enough.
8) No picture... put the tail light back in firmly, then hand-screw the nuts back on, then slightly tighten each nut in a star-shape pattern until they are all evenly tight. (top-left, then bottom-right, top-middle, etc etc) Don't do one up completely tight, then the next, as you could snap or crack some plastic like that. Use the same principal as putting wheel-nuts back on, basically.
Hopefully this has done the job... I think i'd have to dry the carpet first and then let it get wet to really tell if the leak is gone. I'll be smearing a light coat of silicon over that rusty seam on the inside of the boot... I couldn't see any sign of it on the outside.
UPDATE: The tail-light is completely dry now, and it rained all last night. I beleive the problem is solved for me! :)
DIY in response to this thread:
http://www.skylinesaustralia.com/forums/in...20958&st=20
Edited by RANDY
https://www.sau.com.au/forums/topic/126649-how-to-reseal-your-tail-lights/
Thanks for the response with the turps and cutting tips. I didn't want to try turps or anything like that on my paint... I didn't know whether or not it'd be harmful.
According to car audio install places, "wax and grease" remover is what is used to remove the same sealant from your door-trims. I'll be giving that a try when I get time to sound-deaden my doors. ;o)
  • 2 months later...
is it ok to use silicon or do you reccomend using the windscreen stuff ?
Silicone hardens.
For applications like this, it's best to use something which stays pliable and can be removed without causing major headaches.
  • 3 weeks later...
  • 1 year later...
  • 5 months later...
I'm an autoglazier by trade and have to add some important points. What is OEM on the tail-lights is a butyl sealer, it USED to be used for windscreen sealer years ago. Today's windscreens (mainly due to airbags being more commonplace) are installed with polyurethane. The pic of the windscreen sealer used is correct, just make sure it is the NON-SETTING type or you will NEVER get your tail lights out again without destroying them. I don't want to see any of you buye "windscreen sealer" then discovering later that it is urethane based. Silicone does set so I wouldn't recommend it either but is a LOT weaker than urethane. What you want is sometimes called mastic sealer and yes, it's god awful stuff that gets everywhere. Just grap a chunk of it on the end of a spanner or something and tap it onto the bits still on the car. You'll find it sticks to itself better than anything else and should come away in decent lumps. Prepsol (or generic wax and grease remover) removes it and is probably the safest on your paint work, but kero does an excellent job for a lot cheaper. DO NOT drop some on the ground, step in it, then walk on carpets, either in your car or the bedroom, as the missus will discover swear words you never knew existed. That said, WD40 does a surprisingly good job of removing it, and because its a spray, can really get it off car seats etc with the help of a clean rag
Another way to do it that works perfectly is with a product called "Inseal" Made by the Sellotape company.
Rubber strip sealant that is sticky on one side.. just like sellotape! Wow!
This way you can remove the tail lights, IF need be without stabbing yourself and bashing them with wood.
On my old ITR, but would work on the 33 too.
Very tidy and NO mess. Just make sure its joined at the bottom :( For obvious reasons. Never had another drop after this method.
Edited by gotRICE?
  • 4 months later...
Daxter.. I know this might be a bit late, but mine was pretty stubborn too. It's possible that yours may have been removed previously perhaps?
You *could* try heating up the existing sealant with a hairdryer from *inside* the boot. i.e: Heat up the rear panel, around the threads, then push with something solid on two threads (to disperse the pressure a bit.. you don't want to break anything, eh?).
I'd probably suggest getting the whole area behind the taillight very warm to the touch, and if that still fails, heat it up really quite hot. The gooey sealant *should* become really soft and pliable with heat. ;o)
  • 2 years later...
I did this today and all i can say is, what a biatch of a job. Not so complex but gets messy. The trick with getting out the tail lamp unit is to firstly try to scoop out as much sealant with a flathead screwdriver as you can while its in there. Also it helps if you heat it or have it in direct sunlight. have lots of cloths ready and plenty of solvent.
Also be very careful when cleaning the old sealent off the rear lights when its off the car. I had it lens facing down on a clean bit of cardboard, but it turned out that while cleaning off the gunk, little bits of dirt dropped down on the cardboard and as its moving aroud a bit i found i completely scratchew dup one of the lights and panel!! Now i gotta go online and buy a new one. grrr
i just used a hair dryer for about 3 mins going slowly around the edge INSIDE the boot then pressed on the screws with a block of wood. came out easy as. and yes, the sealant is messy stuff, make sure you dont let any get on your paint!
I did this a couple of months back also.
I used a hammer and tapped each of the five screws to break the seal then pushed with hands with even pressure to get it out. I used white spirit and a paint scraper to remove all the black stuff, cleans it up in no time. If you're going to use solvents make sure that you dry it thoroughly otherwise when it rains next the water will mix with the solvent and dissolve the seal...
Don't worry if you get it on your paint it does come off easy, but try to avoid it.
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
