Hey everyone,
Got a quick question....and yes i searched for ages....when i operate the driver's window, up or down; the passenger door always locks itself. Im thinking this may be normal, and its always done it, but its a freaking pain in the ass!
Is there any way of making it not do this? Like cutting a certain wire or something like that...
In R32 btw....
And no i dont want to disable the central locking all together either.
Any help would be great,
Cheers.
Mat.
As far as I know, this shouldn't happen man. You might have a short in the wiring or in the control panel. Check that out first, and failing that, maybe contact an alarm installer if you have an alarm, and get them to sus it out?
Nar havent got an alarm but will soon. Thanks.
Anyone know anything else more specific?
Could it be my door lock timer?
The car has done it ever since its been going...wiggling around wires and connections has no effect either.
my car does that sometimes to. only started after the mongoose alarm was installed...
Tried to figure out when it happened if i:
put the window up
put the window down
auto up
auto down
was all intermittent... still dont know why it does it.
What do you mean by drivers door unit? Is this the small black box located inside the door near where the armrest is?
no. that is the auto up for the windows. the one I'm talking about is the window switch itself. the lock unit is in it.
So maybe try another window switch assembly? Might swap it with a mates and see what happens. Thanks mate.
Mine does that too.
When u auto drivers door down it lock the passenger door when all the way down. Its fkn annoying.
HAHA i wish! even if i move the window up or down just a little bit eg not auto, it still does it!
  • 1 year later...
mine does it too. Only started doing it recently though... I think its an earthing issue. Then again, my power window switch is on the fritz too, almost like the contacts have worn off... so I can't say for sure.
Unfortunately my alarm runs an actuator on the driver door too, so it locks both doors. Seems to be a problem only on R32's.
  • 1 month later...
i have this feature lol
but its not really that bad, there is a passenger door unlock button next to your window controls - atelast on 33's
mine would randomly do it once up to speed, and EVERYTIME i put the rear demister on :thumbsup:
Do a search for a thread by cubes, pretty sure he wrote up a DIY mod to stop it.
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
