  • 5 months later...
Hey
I ended up getting the castrol vmx80 for my gearbox but i never bought any diff oil, i'm about to get some of that redline 75W90 for the diff, the only thing i'm not sure about is do i go for the synthetic oil or the shockproof oil? on there site the 75w90 is listed under synthetic only, not shockproof.
If i do go for shockproof, should i get the superlight - lightweight or Heavy.
thanks
Edited by Hulk1010
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2806116
Redline 75W90 Gear Oil is supposedly good.
I use it in my diff it is very very good , always had problems around roundabouts and tight corners with the inner wheel locking up tried a few oils none were any good , redline fixed my problem
I thought shockproof isn`t an LSD oil only for the gearbox, i use the Blue shockproof in my gearbox its mad too
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2806488
LightWeight ShockProof™
A unique gear oil designed to lubricate racing transmissions and transaxles which see serious loads (not recommended for most syncro-type transmissions). It has excellent low-temperature flow which allows easier shifting when cold. May be used to obtain maximum power transfer in racing differentials which do not see high temperatures. Similar to a 75W140 gear oil, but with the lower internal friction of an SAE 30 motor oil.
Used in two-stroke and four-stroke motocross transmissions (often mixed in equal parts with SuperLight ShockProof™ Gear Oil).
Used in most road-racing differentials with moderate power and dogring racing transaxles.
Taken off the redline website , funny it not recommended for most synro gearboxes works mad in mine
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2807902
Yeah I'd make sure its suited to LSD diff's though..
You don't need "LSD" oil for a standard viscous diff. the viscous LSD unit is sealed from the rest of the diff enclosure and has its own fluid.
If you have a clutch type LSD (ie, you have a GTR, or your diff centre is aftermarket, or you have a skyline with A-LSD) then you need an "LSD" oil with friction modifiers in order for the clutch plates to work properly.
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2808155
I went to repco, autobahn and super cheat auto today and none of them had any redline products that i could see, where can i buy this stuff besides online?
--Nevermind just found some contact locations on there site--
Edited by Hulk1010
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2820264
instead of wasting your money on expensive redline which wont' do anything, because your diff is viscious (separate fluid for the viscous), I would honestly, use a castrol fluid.
Castrol lsx90. Cost ya about $30 for a 4L big bottle. You'll need 1.8L.
Castrol oils are a fairly good place to start from. At least it'll be correct.
Then, see how it feels, if it's good, then fine, it's good. From there, if you have a problem, then go mucking around with different fluids.
I have a mech diff, so I'm using motul oil, just so it changes the properties (won't do much to a viscous).
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2820448
So you only need LSD oil for a mechanical LSD? And viscous LSD has a sealed in amount of its own special fluid you dont ever need to change??
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2821002
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
