instead of wasting your money on expensive redline which wont' do anything, because your diff is viscious (separate fluid for the viscous), I would honestly, use a castrol fluid.
Castrol lsx90. Cost ya about $30 for a 4L big bottle. You'll need 1.8L.
Castrol oils are a fairly good place to start from. At least it'll be correct.
Then, see how it feels, if it's good, then fine, it's good. From there, if you have a problem, then go mucking around with different fluids.
I have a mech diff, so I'm using motul oil, just so it changes the properties (won't do much to a viscous).
For the VLSDs used in GTSTs...the castrol Syntrax 75W90 is a good product...GL5 rated. Bit more expensive but great.
https://www.sau.com.au/forums/topic/126666-diff-oil/page/2/#findComment-2829141
My questino for you is WHY (no pun or offence intended, just seeking information)?
Why use a gearbox oil in an LSD? The LSD should be using LSD oil with friction modifiers (yes I am aware that vlsd haev a separate oil/transfer fluid).
Why use a synthetic oil that will essentially be more slippery, when you want it to grip more?
Why waste money on something that is not required? Essentially the syntrax is $30 a litre rrp as opposed to about $8 a litre rrp for the lsx90 (trade price is a bit cheaper)
PS: In a gearbox, I can see the benefit of using the syntrax synthetic as opposed to the vmx80.
https://www.sau.com.au/forums/topic/126666-diff-oil/page/2/#findComment-2832030
In a true LSD, i.e. non VLSD you would use a friction modifed gear oil. The GTST stock runs a VLSD so you dont require the friction modifiers.
LSX90 is a LSD friction modified mineral base oil.
For a VLSD..gb oil is fine. Syntrax is a high quality 75W-90 syn oil and is suitable.
considering its like 1.2 litres and stays there for ages then I choose Syntrax for my GTST. Syn oil and "slippery" is a crock and its more about the oils resistance to sheer under high pressure and temps. The SAE rating will determine ur viscosity.
https://www.sau.com.au/forums/topic/126666-diff-oil/page/2/#findComment-2832410
It's actually 1.8L, well, for my car it is anyways.
But I have always subscribed to the theory that changing oil more frequently is more important as opposed to running a more expensive oil.
e.g. have you dropped your diff oil after about 10000ks?
Depending on how you drive, I always find that my oil is all burnt and gross. My car is not a daily driver though, so I don't drive it normally etc.
I have no problem using the lsx90. I'd rather buy lsx90, comes in a big 4L bottle. I change it once a year, so the oil is nice and fresh.
That is, opposed to putting in synthetic oil, and leavin git for the time in the manual (like 40 k ks or somethign from memory)
https://www.sau.com.au/forums/topic/126666-diff-oil/page/2/#findComment-2832482
there's no point in using ANY oil past the point at which it starts to break down. however, that might be 3000km for a mineral oil, 5000km for a basic synthetic or 10,000km for a top shelf synthetic. so if you buy a cheaper oil you will have to change it more often anyway.
i'd rather buy good quality, full synth oil and change it "often enough". grab a sample of basic mineral oil (GTX3) and a good synth oil, and rub each one between your fingers. the full synth one is a LOT slipperier.
https://www.sau.com.au/forums/topic/126666-diff-oil/page/2/#findComment-2837336
Personal prefernce. I will change it every year also with the good stuff maybe more sometime cos I get bored. I dont give a toss if it costs me an extra $40/50 or even $100 a year.
I do UOAs on my oil and have used these to detmine what is a. a good oil and b. how long to run it unde rmy driving conditions.
https://www.sau.com.au/forums/topic/126666-diff-oil/page/2/#findComment-2837397
  • 1 year later...
so i shouldnt be using the redline shockproof in the Diff?
https://www.sau.com.au/forums/topic/126666-diff-oil/page/2/#findComment-4326080
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
