Guys,
I've been doing a bit of research and found a place called Amanda's in Pokolbin. It's about an hours drive from Gosford and I've also had a suggestion on a VERY nice drive to get there from Gosford that I'll suss out as well.
Amanda's is a Rastaurant run at Windsor's Edge Vineyard in Pokolbin. I've been informed by the owner that the view from the Restaurant is amazing and over looks alot of other Vineyards. The setting seems to be a very realxing and quiet one which would be perfect for a relaxing lunch and they have PLENTY of secure parking available for all of us :P
We have been offered the private dining room which will comfortably seat us all. They can do a 2 course Lunch for us which will be a choice of 3 entre's, and 3 mains, freshly baked bread and coffee. Dessert will be optional. The menu looks VERY appertising. Cost will be $45 a head for the lunch and again, dessert is optional and will cost extra.
If you would like to see the menu, then click here.
If you would like to check out the place, the their website is http://www.amandas.com.au/
Can I get an idea on how many people will be comfortable with this arrangement. I am looking to book by tuesday so please let me know if you are interested.
I will still be looking at alternative arrangements that may be a little cheaper.
Thanks guys :(
Good choice Tosh!
That place is literally 2 mins walk from my cabin.. yeah baby
Very nice place too, I had some top food there once, and they have REALLY nice wines.
Benm: we couldn't do the BBQ because the facilities are just not available. Amanda's is a top place!
Has anyone confirmed what the view of Amanda is like? :D
I don't know what you mean by 'view'
1) if you mean the surrounds of the place, it's gorgeous, right in the middle of the vineyards.
2) if your talking about the service staff then you'll be a little dissapointed.. they are kinda older women. (say about 45-50)
But lovely people..
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
