hay guys and girls, just woundeering what you think about puting a stage one shift kit on my R31 gxe skyline, is it worth it, i dont want to go overboard but i want to just get that little bit more out of it, also i was thinking about a B & m mega shifter, is there a way that i can wire the overdrive buutton up to the dash, as if i get the shifter it doesent have one on it, as i live in geelong victoria, just woundering if anyone from this area new of any goop places to go and talk to a professional about all this, cheers shaun :blush:
https://www.sau.com.au/forums/topic/126700-shift-kit-stage-one/
hay guys and girls, just woundeering what you think about puting a stage one shift kit on my R31 gxe skyline, is it worth it, i dont want to go overboard but i want to just get that little bit more out of it, also i was thinking about a B & m mega shifter, is there a way that i can wire the overdrive buutton up to the dash, as if i get the shifter it doesent have one on it, as i live in geelong victoria, just woundering if anyone from this area new of any goop places to go and talk to a professional about all this, cheers shaun :wave:
im not good at explaining things so go and look it up in google, it will tell u everything u need to know,
JUST DID!
Shift Kit Stage One, stage 1 shift kit, R31 stage 1 shift kit, Nissan Skyline R31 Shift Kit Stage One, and many other derivatives all DREW A BLANK.
Now maybe you could try to explain or show me where I can find it via a link maybe.
But other than a stick of gelly, I can't see much point of any mod to a GXL R31, unless you got a heap of bucks to through around.
Cheers, D
i would have throught it was just a stage 1 short shift kit
This is my exact point Josh.
What's stage ONE (1)?
Short shifters shorten the throw by about 20mm, so I guess a stage one (1) is less, maybe only 5 or 10mm.
If this is the case, do all of us with 20mm have the full house real racer, stage 4 or 5 short shifters.
And for interest, does your MR30 have the short shift kit in it?
Cheers, D
Thank you AgentR31,
The mind boggles a bit why anyone would want to performance mod an auto R31.
I wanted a tow car for my HR30, so I just put a V8 into my Cressida, all problems solved, will pull the side off a house.
Cheers, D
Thank you AgentR31,
Cheers, D
I modded an Auto R31 Ghostrider. After the Turbo went in, the stock auto lasted about 2 seconds. (Slight exageration there). And I decided to keep the car auto, rather than go the manual conversion. With an Auto, they stay on boost and have less lag. Brescani racing have their cars as auto as well, and I would assume its for the same reason.
Wouldn't bother putting a shift kit in one though. Waste of money if you are going to do nothing else. A manual conversion is always another option, if you can't afford to do an auto properly, but its always good to know what you are doing with a manual conversion as well. I have seen some shockers.
Yarra Valley Automatics rebuilt my series 3 auto to handle 300 KW, and it does a fine job with 225 KW, (flywheel). BUT, I have a manual car as well, so I can still get my manual fix.
Thanks CAZZ,
But I assume your referring to Bresciani Racing, and as they are a predominantly drag (ET) oriented business, I would assume their cars were AUTO for a whole diferent reason than you're inferring.
I would also assume the transmission was a 2 speed Powerglide, same as near every quick drag car runs, from top liner's down and they don't use them to stay on boost, they use them because they will handle massive amounts of HP, that top line drag cars produce.
As for your auto conversion, your very much off the track and out of line, cause this person/member wanted to do it on the cheap, and there is and was nothing cheap about yours or my conversion.
Cheers, D
Thanks CAZZ,
Cheers, D
Thanks for the spelling correction and extra info Ghostrider. I knew it was also because of HP that they use auto's, but I didn't know they used powerglides. Watching those cars in action, is certainly a sight to behold though. Go the RB30.
Thank you AgentR31,
Cheers, D
But do the headlights now work?
:D
stage one shift kitting an auto makes it change gears firmer, hold out a little bit longer ect ect probably good for a tow car
its not worth it for the money you will pay (up to $2000) for that price you can go manual and shift as hard as you want
Why not use the auto gear changer and select the gear you want,
I take it for dragging or similar, pull it back to low (first), change to second, change to third etc.. when you run out of reves. Cheap as chickens..
True, but that won't allow you to keep the gearbox in one piece if you increse the power output significantly over stock.
Generally speaking a 'stage 1' shift kit includes modification to the valve body to provide firmer shifts (less slip=less heat) and higher clamping pressures (more holding capacity), and a larger cooler. Moving on from there you can increase the firmness further (at the expense of ride quality), and modify the clutches to cope with more power. From that point you are looking at increasing the strength of the input shaft, and possibly the planetary gearsets themselves. You're probably also in the realm of manual valve bodies & transbrakes if you're this serious.
My Z 3-speed has a custom modified valve body (it shifts HARD), Kevlar clutches, a slightly higher stall-speed converter (a 4-cylinder converter can be an easy swap for a few more stall-rpm out of your 6), and raised shift rpm points. It does have to cope with the best part of 300HP, and the standard box would be a horrid thing in these conditions (burnt out clutches would be a regular problem - resulting in complete rebuilds).
Most of this stuff is useless in a stock motor, but a 'stage 1' kit is useful when towing, as the transmission is doing more work and the reliability does benefit from the extra cooling & slightly firmer shifts.
A slightly raised stall speed can also wake up an engine, especially if it is suffering from the low speed effects of a modified camshaft, or has a larger-than-stock turbo. An otherwise standard RB30ET feels noticably crisper with a lightly modified gearbox & raised higher stall speed.
Cool, sound like you know your stuff..
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
