There are heaps of importers around, but unless the car is already here then you won't be able to get much, as the RAWS is about to come into effect. That means that only the few dealers which have met the RAWS accreditation will be able to get you a decent car.
See'ya:burnout:
https://www.sau.com.au/forums/topic/12677-importers/#findComment-232768
James,
I've got plenty of Skyline's and Silvias in stock, with more coming, but alas I sell my cars at retail prices. What you get for that is a car that is licenced and fully prepared to the highest standards.
My website is www.c-red.com.au
Regards,
Jash
https://www.sau.com.au/forums/topic/12677-importers/#findComment-233316
Hey James, If you choose to got through a broker to get something imported your going to get something pretty ordinary now that the new laws have been layed out, get something thats already here that you can see, theres plenty around
https://www.sau.com.au/forums/topic/12677-importers/#findComment-233366
James,
I bought my Skyline from Down Under Autos in Jan this year(www.downunderauto.com.au) and they provided a good car and a good deal. They have some Skylines in stock (I've just checked) and they are members of the RAC Dealer Check set up (i.e. all their cars are checked by RAC). If you want any more details, then pm me. I am sure that there are other good dealers around, but I can't comment on those. In the end, it comes down to whoever you feel comfortable with. However, you should get a good enough deal with the specialist dealers who have Skylines in stock, compared to going through an importer. Also as the other guys have said, it is all changing at the moment, not too many people have compliance plates and prices are going to go up as supplies slow down.
Good luck with it.
Cheers.
https://www.sau.com.au/forums/topic/12677-importers/#findComment-233365
on the subject of raws have been talkin to a company that is going through the raws accreditation. As i'm buying the mrs a jsx100 chaser myself and they r complying it in late april they said basically the new system is roughly the same with a few more criterias to obey. With less dodgy dealers and back yard importers bringing in dodgy cars
So really the end buyer is in a win win situation.
And as for those pre buyin checks as a motor mechanic those checks are only good as the person checkin them.
Ive seen a few cars bought at dealers. Suggesting the vehicle is in excellent condition and ive picked the crap out of em.
so fair enough the dealer getting the checks done but also have the thing checked out thoroughly at a registered well known work shop before you hand over the cash. Just a bit of advise
https://www.sau.com.au/forums/topic/12677-importers/#findComment-236039
bought both my cars here and i seem to have had a lot less grief than the people that have imported. Ive heard that with the new laws the cars have to be pretty much stock standard before they are let in too. I guess the advantage of having it already here is theres no waiting and you can have it fully checked out....... but if u get it imported u save a bit of cash but there could be a few griefs and hassles getting it here etc.
Because your dad works where he works - why dont u get one there james? get one of those guys to bring it in?
https://www.sau.com.au/forums/topic/12677-importers/#findComment-236124
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
