Gday All,
As of last night my oil pressure guage will read normal and then randomly and independent of rpm, will drop to almost 0. When the engine rpm is increased the pressure will rise but not as much as normal. It is reduced by about half of the normal readings at any given rpm.
I am wondering whether it is a voltage issue or guage issue or worst of all, an actual oil pressure problem.
Any insight into this problem is appreciated. Car is a 1989 GT-R.
Cheers,
Ben.
https://www.sau.com.au/forums/topic/126770-oil-pressure-problems/
colar is most likely stuffed on the pump, again take it to a mechanic and get an independant reading done by removing the sender, but I would be betting on it being the colar.
yes it could still be the sender of cluster itself but I myself wouldnt be taking that risk.
I did once and I ended up rebuiling the motor.
Edited by James_03
Damn I just replaced the crank and rods and the Oil press sender (from another RB) and its doing the same thing and reading all over the place.
I thought it was just the gauge before but the clattering noise was a bit of a giveaway as well so expected problems.
Found out it was the countersunk screws in the back of the oil pump had come right out!
So dont think its the sender unless proven, but hopefully this time it is!
I think I will avoid running the engine completely to be safe. can't afford a rebuilt right now.
Thanks heaps for the replies. You guys are lifesavers.
Yea I know the feeling. Dont know whats wrong with it and kinda hope its not anything bad. Seeing it read 0 is scarey. Esp when you dont or not plan for rebuilds. :wave:
when my gauge reads zero... my mental argument is that the red warning light doesn't come on, so not to worry. When that light starts coming on, then i'll worry!!
My guage has been playing up for roughly a year, and i've been drifting the car, almost weekly. So, if something was wrong with the oil pump, i figure my engine would have blown itself up a long time ago
red light and gauge are independant, when the red light comes on you have no oil pressure. i have similier issues, mine always reads low, but i have seen it drop to zero when i came to a stop once, also it moves under heavy breaking.
Edited by Jolinator
Well, good news. It is the sender unit. The car had 90PSI at cold idle.
Now to find a cost effective replacement, I hear the nissan genuine units are $220 odd.
A big thanks to Dan (3lit3 32) for taking the time to drive 45 minutes to help me out.
For some reason and for the first time in about 3 weeks, the guage seems to be working. It was reading almost zero after driving for a while but yesterday it was at 6 when starting then made it's way down to 2 and stayed there until i revved it and then it went up and then back down to normal.
Hopefully it stays working but i won't count on it.
I replaced my sender unit with a new one, had similar problems, and also connected a mechanical gauge and compared the results to the original dash mounted GTR gauge.
Interesting results.......
While the mechanical gauge can be reading a steady figure say 45psi the Nissan gauge can vary between 2 to 3 KG/cm3 depending on its mood. Also at idle the mech gauge reads 30PSI rock steady the nissan gauge still reads high at around 40psi equivilent. At 4000rpm the mech gauge is up around 80PSI the nissan gauge still reads about 4 kg/cm3. So even with a decent sender the Nissan gauge is really a indicator that you have oil pressure, how much exactly can only be sorted with a good mechanical gauge fitted.
Mike
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
