Gday All,
As of last night my oil pressure guage will read normal and then randomly and independent of rpm, will drop to almost 0. When the engine rpm is increased the pressure will rise but not as much as normal. It is reduced by about half of the normal readings at any given rpm.
I am wondering whether it is a voltage issue or guage issue or worst of all, an actual oil pressure problem.
Any insight into this problem is appreciated. Car is a 1989 GT-R.
Cheers,
Ben.
https://www.sau.com.au/forums/topic/126770-oil-pressure-problems/
colar is most likely stuffed on the pump, again take it to a mechanic and get an independant reading done by removing the sender, but I would be betting on it being the colar.
yes it could still be the sender of cluster itself but I myself wouldnt be taking that risk.
I did once and I ended up rebuiling the motor.
Edited by James_03
Damn I just replaced the crank and rods and the Oil press sender (from another RB) and its doing the same thing and reading all over the place.
I thought it was just the gauge before but the clattering noise was a bit of a giveaway as well so expected problems.
Found out it was the countersunk screws in the back of the oil pump had come right out!
So dont think its the sender unless proven, but hopefully this time it is!
I think I will avoid running the engine completely to be safe. can't afford a rebuilt right now.
Thanks heaps for the replies. You guys are lifesavers.
Yea I know the feeling. Dont know whats wrong with it and kinda hope its not anything bad. Seeing it read 0 is scarey. Esp when you dont or not plan for rebuilds. :wave:
when my gauge reads zero... my mental argument is that the red warning light doesn't come on, so not to worry. When that light starts coming on, then i'll worry!!
My guage has been playing up for roughly a year, and i've been drifting the car, almost weekly. So, if something was wrong with the oil pump, i figure my engine would have blown itself up a long time ago
red light and gauge are independant, when the red light comes on you have no oil pressure. i have similier issues, mine always reads low, but i have seen it drop to zero when i came to a stop once, also it moves under heavy breaking.
Edited by Jolinator
Well, good news. It is the sender unit. The car had 90PSI at cold idle.
Now to find a cost effective replacement, I hear the nissan genuine units are $220 odd.
A big thanks to Dan (3lit3 32) for taking the time to drive 45 minutes to help me out.
For some reason and for the first time in about 3 weeks, the guage seems to be working. It was reading almost zero after driving for a while but yesterday it was at 6 when starting then made it's way down to 2 and stayed there until i revved it and then it went up and then back down to normal.
Hopefully it stays working but i won't count on it.
I replaced my sender unit with a new one, had similar problems, and also connected a mechanical gauge and compared the results to the original dash mounted GTR gauge.
Interesting results.......
While the mechanical gauge can be reading a steady figure say 45psi the Nissan gauge can vary between 2 to 3 KG/cm3 depending on its mood. Also at idle the mech gauge reads 30PSI rock steady the nissan gauge still reads high at around 40psi equivilent. At 4000rpm the mech gauge is up around 80PSI the nissan gauge still reads about 4 kg/cm3. So even with a decent sender the Nissan gauge is really a indicator that you have oil pressure, how much exactly can only be sorted with a good mechanical gauge fitted.
Mike
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
    • I'm late to the party. Been busy with a newborn... Keeping me up at all hours of the night.  I'll look into purchasing ID 1750's then! Thanks everyone for the concrete evidence.
