Ok guys need a quick bit of advice, I decieded to do a radiator flush as it was beginning to look a little dirty, now ever since if i give the car any guts it begins to get very hot...... now a little back ground, the hoses are quiet soft !! so im thinking of replacing then anyways, but im wondering if o may have clogged the radiator or the theromstate??? im a little lost, cause i flushed it another time thinking that would help !! but it doesnt seen to have helped...
also aboyut 2 weeks ago i somehow misplaced my radiator cap so i got anothter on and just thinking maybe it not suitable for a r33 GTST ??? and help or agvice would be benificial ... should i take the tadiator out and do a major flush of the engin and radiator ? repace the thermo??
thanks guys
https://www.sau.com.au/forums/topic/126790-overheating/
getting them properly flushed mean having the end tanks taken off, and due to the age of these cars there is usually hairline cracks in the tanks, which means new tanks when getting that done, take it out and geta quote.
re: cap for radiator, you see the coolant spilling out of the overflow tank?
did you Bleed the radiator system properly when you refilled it after the flush?
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341211
thanks for the quick reply !! i did bleed the entire system and bleed and air trapped in the system, it did once have coolant spill over the overflow the first time it got hot... but hasnt done it since, also stupid question !! but could it also possibly be incorrect coolant?? im usesing a stock standand Radicool "type A" coolant? should have i used a turbo specific high grade coolant??
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341237
coolant is the same
remember that adding more coolant increases the boiling point of the fluid, but DOES NOT make it better at cooling. so as lonmg as there is no leaks and the coolant is diluted, it could be a blockage.
doubt it would be the thermostat as if that didn't open you would not see the high temps
sounds like a blockage in the radiator..
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341289
coolant is the same
so would it be a good idea to take the radiator out and give iot a good flush??
or is there something i can use to do the job?? or should i have someone who totally knows what they are doing?? like i have the confidence to do it myself !1 i jsut dont want to make the problem any worse ....
thanks so much for the advice
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341356
your flush you did included removing the radiator and pumping some high pressure water through it before putting it back in the car ????
proper flush will costs you if the end tanks are cracking, cos when they remove them they usually damaged and need to be replaced
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341464
No i didnt take it out !! was just a general clean and flush,,, thew end tanks where are they situated !! and doesn the radiator just slip out once it been taken off the manafold?? and what kind of cost are u thinknig ?? just an estimate??
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341475
couple of hundred at least.
the end task are the plastic bit on the radiator... like where the pipes go into it .. and the rad cap is located
if you are going to do track days, look into getting a quote from a radiator place... if its a few hundred look into getting a bigger radiator
http://www.justjap.com/parts_ncooling.htm
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341508
Sorry bout all the stupid questions !! just a little worrieD and i want the car back fully on the road !! interesting fact i can drive it for quiet awhile without the heat riseing !1 it just if i put my foot down a little ...???
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341517
could be the thermo not opening enough to flow enough with the increased heat from a thrashing, or the radiator not having enough flow to cool enough after a thrashing..
change the thermostat if you can do it yourself, be cheaper fix, if it dont work then atleast you wont have to worry about it later
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341533
When you say it becomes very hot, do you mean it keeps rising or it just runs hotter than before?
The reason I ask is because if the thermostat is stuffed and no longer opening you won't have any coolant circulating and it'll bake itself. Craved dude I don't understand why you said " if that didn't open you would not see the high temps". Could you please explain a little more? As far as I know, if the thermostat stays closed to assist in warming the block and once it reaches operating temp, it opens, allowing coolant in, to prevent high temps...?
Happily corrected if I have things ass about.
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341545
it could be a number of things...
blocked radiator, air pocket trapped in the system, faulty thermostat, etc..
a way you can check for a blocked radiator - disconnect both hoses from the radiator and put your garden hose in the top connection. Is the water filling up inside and then coming back out the top? is there any water coming out the bottom connection? if so, is it the same amount as you're putting in?
did you bleed the air out of the system at the plenum?
are you losing any coolant?
to give you an idea of prices, i had my radiator professionally cleaned and rebuilt for around $250, that included new end tanks.
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341550
cool !! ill do that on the weekend, ill do the hoses and the thermostat, and then and only then ill have to get it look at by someone !! so ill do another minor flush and do those couple things, fingers crossed, thanks for the advice, ill let u know if any changes occur.
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341558
i might be having a mental blank, but the temp sensors are located after the thermo, so if its not open then the water on the temp sensor side isn't as hot as inside the engine...
hence why a car stays at cold til it sort of suddenly gets warm when the thermo opens.
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341556
oh another question !! a thermostat, how much u think ?? i had a look and a nismo ine was about $150... i thought they were about 50 - 70$
https://www.sau.com.au/forums/topic/126790-overheating/#findComment-2341570
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.   As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.    I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.   Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.       BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
    • Yeah, I wasn't giving two f**ks for the ring running around the bore. I was looking at the vertical scratches running up and down across the hatch marks.
