I didn't use a jun collar.
I took my r32 gtr crank to an engineering workshop and got them to machine the nose down and heat shrink a 4140 moly sleeve onto it.
They then machined it to r33 gtr specs.
They charged me $169 all up for everything but prices elsewhere could vary.
They can get most of the measurements they need from the r32 crank before they machine it down.
You just need to tell them how long to machine the flats.
If you go for a jun collar they still have to machine the crank and heat shrink it on.
got the collar with the pump...good price too...thanks CRD
so ill fit it...looks like the nose of the crank is machined and the collar is pressed on.
it comes with two grub screws so they will hold it in place.
I build my own engines.
thanks Nik (amaru)
I take it the grub screws are inserted 90deg from the drive faces (flats)?
The grub screws are just an extra precaution. You need to machine the crank to the right clearance (negative) for an interference fit.
Bob Lee at Action cranks has fitted squillions of them for a lot of engine builders.
when we do our we oil bath the collar also so its a little tighter on the tolerance (heat bath etc), but yeah as mentioned, machine the old drive off the crank, tolerance fit the new one, and drill grub screws on the flats of the drive ensuring they are bellow deck height, lock tite them in and your away.
Bingo, exactly what we did with our rb30det in the racecar. Except it was an rb30 crank obviously. Has worked with no dramas so far. I must say the drive section of the collar is massive in comparison to the std drive on the crank, well once again for rb30 crank lol. Bigger is better in these circumstances strangely enough.
It's a 2 thou interference fit. Then put the crank in the fridge and the collar in the oven and press it on. Temperatures normalise and it ain't going anywhere. Grub screws are just a precaution.
>_< cheers :wave:
Edited by Sydneykid
>_< cheers :wave:
some say to put the screws in on the flats...and others say 90deg from the flat face. Will a rebalance be needed??
We put them on the flats, I am not sure that it matters. They are also loctited in of course.
The diameter and weight of the flange is not really enough to put the crank out of balance.
That said, I always check the balance of RB cranks every time I disassemble an engine. It’s cheap insurance.
>_< cheers :wave:
:wave: cheers :wave:
Yeah...same...will balance after collar fitted
FOr the 30 mins it takes to check the balance we always do it!! I have never put the screws on the round side always on the flats, dont think it matters as mentioned there a precautionary measure.
We dont need a freezer in canberra just leave them outside in the morning in winter in canberra and bingo you have a crank thats -4 in temp!!!hahaha
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
