Jun Crank Collar
I didn't use a jun collar.
I took my r32 gtr crank to an engineering workshop and got them to machine the nose down and heat shrink a 4140 moly sleeve onto it.
They then machined it to r33 gtr specs.
They charged me $169 all up for everything but prices elsewhere could vary.
They can get most of the measurements they need from the r32 crank before they machine it down.
You just need to tell them how long to machine the flats.
If you go for a jun collar they still have to machine the crank and heat shrink it on.
got the collar with the pump...good price too...thanks CRD
so ill fit it...looks like the nose of the crank is machined and the collar is pressed on.
it comes with two grub screws so they will hold it in place.
I build my own engines.
thanks Nik (amaru)
I take it the grub screws are inserted 90deg from the drive faces (flats)?
The grub screws are just an extra precaution. You need to machine the crank to the right clearance (negative) for an interference fit.
Bob Lee at Action cranks has fitted squillions of them for a lot of engine builders.
when we do our we oil bath the collar also so its a little tighter on the tolerance (heat bath etc), but yeah as mentioned, machine the old drive off the crank, tolerance fit the new one, and drill grub screws on the flats of the drive ensuring they are bellow deck height, lock tite them in and your away.
Bingo, exactly what we did with our rb30det in the racecar. Except it was an rb30 crank obviously. Has worked with no dramas so far. I must say the drive section of the collar is massive in comparison to the std drive on the crank, well once again for rb30 crank lol. Bigger is better in these circumstances strangely enough.
It's a 2 thou interference fit. Then put the crank in the fridge and the collar in the oven and press it on. Temperatures normalise and it ain't going anywhere. Grub screws are just a precaution.
>_< cheers :wave:
Edited by Sydneykid
>_< cheers :wave:
some say to put the screws in on the flats...and others say 90deg from the flat face. Will a rebalance be needed??
We put them on the flats, I am not sure that it matters. They are also loctited in of course.
The diameter and weight of the flange is not really enough to put the crank out of balance.
That said, I always check the balance of RB cranks every time I disassemble an engine. It’s cheap insurance.
>_< cheers :wave:
:wave: cheers :wave:
Yeah...same...will balance after collar fitted
FOr the 30 mins it takes to check the balance we always do it!! I have never put the screws on the round side always on the flats, dont think it matters as mentioned there a precautionary measure.
We dont need a freezer in canberra just leave them outside in the morning in winter in canberra and bingo you have a crank thats -4 in temp!!!hahaha
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
