Hi...
Injectors were leaking fuel but the car still run fine, drove it this morning to a mates and it was working perfect but when I left it was missing and sounded like a couple of cylinders weren’t running ?? Anyway I took it home and popped the bonnet, 10 sec later I seen smoke coming out around the injectors so I switched the car off straight away.
I changed the injectors and started the car, all idles fine but still has the same problem when I take off and start driving.
Anyway I got some spark plugs to try out, I took off the top cover on the motor and I noticed some stuff that looked like it had leaked out or something from the ignition coil bracket, it smells kinda like burnt plastic and that smell started when the smoke happen (from the leaking fuel im assuming ??)
Anyway ive attached a photo so perhaps someone would know what has happen. Havent done anything else to it yet incase someone can definitely say what the problem is.
Thanks !! :blink:
Max
... Ive pulled off the ignition coil bracket and seen that one or more are stuffed ... well at least one has melted stuff coming out of it :) *picture added ...
How would something like this happen ? could it have happen from fuel leaking around the head and then smoking up from heat and burning it ?? perhaps some wires ??
Thanks !! :D
Edited by chances
