Item: Battery, hks wastegate, supercat muffler, intercooler
Website:
Item Condition: some used, some new
Reason for Selling: left over parts
Price and Payment Conditions: detailed below, cash or netbank
Extra Info: pickup or postage
Pictures:
Contact Details: pm is best or leave a reply
Oddessy Sealed BatterySOLD
Brand NEW HKS Adjustable Wastegate ActuatorSOLD
Brand NEW IntercoolerSOLD
Supercat Muffler$150
- 3" inlet, 4" tip
- has a bit of rust from the band used to attach to car, small scratches on bottom
- measurements of muffler, all approx. overall length: 45cm, barrel length: 33cm, barrel diametre: 18cm
Edited by digitobi
https://www.sau.com.au/forums/topic/126815-bris-parts-for-sale/
hey mate how does that muffler come up when its clean? Interested... im in brissie area too
FMIC is no-name?
yeah the muffler just needs some polishing. fmic is noname. also the core size is 530x270 i'll fix orginal post
pm sent
your pm box is full. let me know when u delete some stuff
I'll take your HKS wastegate... PM me your details.
ill let u know if the sale to the above person falls through.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
