Hi Guys
I have just joined, and have a Stagea on hold in Japan. I am wondering the best place to get it complied when it arrives. Its a Non-Turbo, RS Four, Series 2, 1999. I still have everything to organise, including shipping (and all payments!!) Any help starting woudl be much appreciated. :devil:
Thanks
https://www.sau.com.au/forums/topic/126857-compliance-in-perth/
Hi Guys
Thanks
ask macnag. he got his car complied in brissy and sending it vis truck back to perth. ce carfull when chossing a compliance center.
Now do you have any aftermarkerts parts installed? Cos that would dictate on the pricing for compliacne as well.
Thanks for the rply, No after markets, car is bog stock....
From my experience recently i would recommend that you send it to Brissie...would not recommend using the place i did in Perth...if you want details send me a PM and ill explain everything!
Otherwise have a look back i think there is another thread called Compliance..i explained the simple stuff of what happened in there!
Honestly save your money go to Brissie and that way you wont pull your hair out!!!
Hi Guys
I have just joined, and have a Stagea on hold in Japan. I am wondering the best place to get it complied when it arrives. Its a Non-Turbo, RS Four, Series 2, 1999. I still have everything to organise, including shipping (and all payments!!) Any help starting woudl be much appreciated. >_<
Thanks
You CAN NOT comply a NON Turbo vehicle
secondly there's no such thing as a non-turbo RS four, it'll be a 25X Four.
Well Actually it doesn't matter any more, as I cancelled the car in Japan this afternoon. No Cost Phew!!
You're all right, can't comply a non turbo. Bugger, really pissed off, but like they say if it sounds too good to be true it probably is!!! the Stag was a silver 99, with 81,000 km, a few bumper scratches (5 in all) a cigarette burn in the center console arm rest, everthing else perfect and my offer of A$2400 was accepted!!. Spent the day trying to organise things, THEN found out about the non-compliance. We obviously need a register for Boring cars as the non-turbo isn't powerful enough!! Seems really stupid. But it wouldn't be the first time a stupid law was made!!!
Back to the drawing board. I guess I'll have to find a Turbo after all, It's just that I want an S2 with FAT, and don't want to end up paying more than have to.
Maybe I'll have to look at Skylines as there is only one person that can comply a Stag in Perth, and they are a dealer too. I've had a look at their (overpriced) stock and I wasn't impressed.
I write more as I find out.
Every day I find out how little I know.... man, this is some learning curve!
I can confirm what darrin said, its under the power to weight requirement of SEVS.
On another note, explain how you have an RS Four nonturbo, as the non turbos are actually 25X Fours from what I know.
Dunno, that's waht the rear badge says, but like I said in another reply it don't matter now!
I'll see if the co. in Japan can find a Turbo for that sort of dosh!! (doubt it ) :)
There is no problems with getting the car even if you dont comply it in Perth I just bought mine and am getting it complied by Shogun/RCN Compliance in Brisbane and they are charging me $3000 for compliance and I am able to arrange shipping for around 500 to 800 bucks which leaves me ahead by $700 to $1000 better off than complying in Perth and they are going to sort any non standard parts for me too so its just too easy. Only got the car 2 weeks ago and have already had the import approval granted and shipping booked.
Use an agent like J-Spec and everything is very easy just sit back wait impatiently and then enjoy your car.
Like Glen says . It is cheaper ,and quicker toget a car sent to Brisvegas, get it complied and truck it to Perth.
I used Prestiege Motorsport in Perth to buy through, and used Iamshe in Southport for compliancing. Phil White is the Man. No hassles cost about $3400 including tyres and lend of stock bits to get it through.
yea i second Phil too. I heard of him from other people said that hes good and resonable price. No BS from him. It pays to call him to check it out.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
