This is the plan .
Build an R31 with a VH41DE ( Nissan V8 4100cc )
Heres what i have .
I bought a VH41DE half cut for $ 1750 delivered
Bought the wagon for off ebay for $ 900 . It has a mint body . Replaced the diff ( $ 80 ) , replaced leaky water pump ( had a spare ) . Got it registered 3 weeks ago .
I plan to keep it looking as stock as possible , even down to the hubcaps .
Am only interested in going fast in a straight line , drags and on the salt flat .
Deliberately chose the 4100 cc engine to suit the class ( F = 3000 - 4300 cc ) i want to run at the salt lake speed trials .
Edited by dondesoto
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/
OK . Here is a pic of the wagon i raced this year at Lake Gairdner speed trials . Was running a RB30DE . Best average speed over 1 mile was 141 .187 MPH ( 227.21 kmh ) . I saw 152 MPH ( tacho reading ) at the end of one run . Engine basically stock with 370 cc injectors , extractors and 2 x rb25 throttle bodies , apexi safc 2 , and thats it . Standard cams and head .... NON TURBO
Edited by dondesoto
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2342582
Nice work on getting the VH41DE.
What sort of Gearbox did it come with? Auto or manual? and what sort of box will you be using?
do you plan on modding the engine or running it stock? How much will it set you back to cet the new engine in and running in the car?
Is your other R31 with the RB30DE for sale :(
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2342808
only ever seen them with auto's behind them... AFAIK they didn't get sold with a manual option..
and every combo we've tried doesn't work, rb/vg/sr etc boxes all have a different bell housing setup, the VQ boxes might go but not sure..
however locally in perth someones developped an adaptor plate to slap a 25 box behind it, well any RB box really, but 25 for the strength, needs a custom flywheel, but its workable, PM me if you need more info on who to speak to
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2343421
Mods will be limited to extractors ( home built ) , cams if i can get the stock cams ground , malpassi fuel pressure reg , Apexi safc 2 and a decent air intake .
I will be doing the installation myself and am going to tackle the wiring up too .
I will be using the auto box the engine come with , cheapest and easiest option for now . Fitting an rb25det box would be a good option , but but would cost more than my whole half cut by the time its fitted .
The red car is not for sale yet, as it will still be my daily driver until i finish the blue cars conversion . Hoewever will be selling the rb30de engine at a latter date , maybe towards the end of the year .
Its not a priority but it would be nice to have it all done for a total of less than $ 5000 ( including purchase of car and half cut ) . 150 Mph + for less than $ 5000 , i like .
Edited by dondesoto
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2343723
Spent many hrs on saturday , disecting the harness . had pulled out all engine bay harness and in car harness . Massive amounts of wiring . Found a total of 6 computers . Only using 2 of the computers , engine management and auto trans . Believe i have all the wiring i need after chopping out one big box full of surplus wiring and electricals .
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2351061
Good luck, the wiring is probably the hardest part of setting something like that up.
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2351209
it is, took my mate a few solid nights and some weekend time to sift thru everything tracing wires to see where they went and what they hooked into, the amount of surplus in the looms is astounding..
AH tell me about it . Have spent many hours unravelling harness . Thought i had it right , then discovered i had chopped out 16 wires too many that go to the transmission ecu , a big BUGGA . Have had a lot of help from NICO forum in sorting that prob out .
  • Like 1
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2357397
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
