Removal Of Oil Catch Can
Beef
 Share
Hey lads, i decided that i really dont need my oil catch can, obviously because im not running enough boost to warrant having one and also there is a lot of oil misting coming from it, and its making a right mess...
do i simply just link the hose back into the top of the engine?
or could anyone show me pics of what should happen with that extra piece of pipe that goes from the crank case thing to the catch tank?
Beef
Edited by Beef
so you want that oil mist that is making a "right mess" to go back into the engine?
if you are getting oil mist, then you NEED a catch can, as that is what it is for... removing the oil from the air/pressure in the cam covers/head.
yeah, maybe your right...
but my car makes 242kw atw... do i really need one?
what is teh actual purpose of an Oil Catch Can?
it was on there when i bought it..
Beef
s as that is what it is for... removing the oil from the air/pressure in the cam covers/head.
this air goes back into the turbo air feed between the turbo and the AFM
without a catch can. that oil that the catch can is collecting goes into your air feed. then into combustion chamber which can actually be a contributing factor to pinging
you dont get to a power level then need one.... if you catch can has got oil in it, then your motor has blowby and will need it.... and you should get a comp test done to check its health as excessive blow by is bad!
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
