huddster - how much it cost mm you?
i got price quoted EMS 6x tomei rb24 pistons $1926
i was *pull collar of shirt*
now the position im in atm is which pistons to use... r33 crank and rods i can pickup anytime...
now its wether or not go genuine tomei pistons or go brand new aftermarket 4agze forgies?
turbo is in the process of being purchased also (waiting on seller to get back to me) TD06-20G high mount kit... currently has 12cm housing... untill the 24 is built (not till next year itll be ready im budgeting) id like to use an 8cm housing if roy/sk have one laying around? :)
That the reason for my suggestion, $400 for new 4AGZE pistons or in my case $120 for a set of used ones and $90 for a new set of rings.
For $1926 you could just about buy a set of forged pistons and rods for an RB30. Which will make a heap more power than an RB24 ever will.
Hence my suggestion, forget the RB24 and build an RB30 instead.
:) cheers :D
SK hush - you will not persuade me!
im doing it for the little man... the little man in japan which designed the rb20!
he started a revolution for us all! i am going to expand on his starting point!
that and a high rpm will be quite handy for the drift with the td0620g which should provide a nice torquey powerband in efficiency range of about 1.4bar all the way through :D
certainly the 8cm housing im after atm for my stock rb20 as a temp thing i would not use - more so reverting back to the 12cm housing coming with the kit for the 24 as the added capacity and low down torque will still retain a similar spool timeframe for coming on boost and also effectively maximise the efficiency of the high rpm rb24 :)
rb20 base FTW!
rb20 base FTW!
I am not trying to change your mind, just make sure you understand why certain parts are chosen when doing the RB24. Sure you can make more power by spending $2K on pistons, but it's not good value for money. Spend $400 on 4AGZE's and be happy with the result or spend $2K and keep in mind that you could have bought RB30 pistons AND rods for the same amount.
I do sugest you start watching the Japanese on line auctions, cheap RB20 stuff comes up occassionally.
:D cheers :D
PS; that same little man probably designed the RB30ET 3 years earlier.
Edited by Sydneykid
ouch!
always watching auctions... tomei built rb24 with rb26 rocker covers and cam cover went up about 3 months ago... 120,000yen only 8,000kms used... genuine tomei cams, pistons, rods, crank everything... i shouldve bought that but instead i bought another set of work vs-kf
madgt4 would remember this engine - me tearing my hair out in the final mins of the auction deciding which to take... wheels or engine! damn am i dumb!
rods are cost efficient to purchase from jp which i am doing however crank i will be purchasing locally as they arent that exxy here and can gurantee no transport damage or anything!
question is... who to build now... several suggestions so far
and need an 8cm td06-20g housing also!
Forgetting whether its an RB20, 25, 26 or 30...be realistic with what you want from your car. A std engine with the right bolt ons will make crazy power...you dont have to run out and buy rods, pistons, JUn Oil pumps etc etc.
I have been buying parts here and there when i have some spare cash. If the RB20 dies then i will build up this other engine...but right now i can sell the gear i have bought and not lose money...im hoping i never have to build this motor up as when you sit down and add up the bolts, gaskets, fluids etc etc it is damn expensive. Add you will need injectors and and gearbox and i cant brign myself to spend over 10k to go a little bit quicker.
A well sorted std RB20 will run well into the 12s...so how much are you willign to spend to go quicker???
as stated above roy not for speed... reliability, longetivity, torque, powerband and higher rpm ranges
car is for the track... not street registered! so once a fortnight itll be thrashed for a day!
either way any idea on td06 8cm housing?
Good on ya mate.. this has been interesting to watch how much money your coming up against..
i hope mine wont cost this much..
Ive been told to do the rb25 too.. and it just wont happen.. theres something not right about them
Rb20 powah FTW!
not that it really matters but isn't it if you use the rb25 crank and rods its classified as an rb23 and if you use the GTR rods and crank its an RB24?
I was in the same possy as you about a year ago debating whether to go the rb24 or the rb30, i ended up going the 30det and haven't looked back since but props to you for going the RB24 and with you being in S.A i look forward to seeing it out at the track!
Good Luck!
  • 1 month later...
ok im confused i thought an rb24 was built by putin 20 cons and crank in a 25 block with 25 pistons please correct me if im wrong decause i am considering the 24 rought
im sure there is more than 1 method but i would really like some help
the reason for my choise on rb24 is i want the extra tourque but as little cappasity as possible with rising fuel costs
Thats retarded, the extra flow of the 25 head would probably make up for the extra fuel consumption of the whopping .1L increase in capacity.
Also there are people on here with big power RB30DETs getting better economy then my stock RB20. If fuel economy is your concern theres a million other facts that contribute to it.
Edited by Rolls
  • 3 weeks later...
just a note with the use of the two different pistons......
if you use the Tomei Pistons....82mm ..it will get you in the 2350cc mark with the GTR Crank....but if u use the Toyota pistons with GTR crank .. it will get you a figure around... 2260cc or there abouts.
there not quite the same
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
