Long story short -
1. car spluttering / not running smoothly when cruising in 4th gear @ 2800rpm (after 20 mins of driving / car warm) plus leaky injectors were getting really bad.
2. next day melted a coil.
3. changed all the injectors & replaced the coil - all good again.
4. took it for a drive today - same problem after the car is warm ... revs fine and goes hard still anytime but when im cruisin the car jumps back and fourth a little and runs all crappy.
ok ... so its not the injectors, could be one of the other coils but i just wanted to know if the airflow meters would be affected by heat ? ive only just put on a set of hks airpods and ive noticed all the piping and the outside of the airpods were really hot after i come home, just wanna know if this could be the problem or perhaps an 02 sensor ? but yea the car runs perfect untill its warmed up ... then it just wont cruise nicely :P
Thanks
Max
https://www.sau.com.au/forums/topic/126931-r32-gtr-hesitates-while-cruising/
  • Replies 45
Posted Images
ive got the same problem
i doubt it would be o2 sensors because if they were faulty, ie, not doing their job, then they wouldnt be leaning out the mixture on cruise. thus keeping the mixture richer and smoother.
i think the jerkiness i get with my gtr is due to dirty injectors having a terrible spray pattern at lower fuel pressures (ie cruising) from running a few tanks of petrol bloody low. however, you said youve changed the injectors
to be an AFM problem, you would feel the 'cutting in' and 'out' on all loads.
i reckon its still a fuel delivery problem. hows your fuel filter? changed it recently? these old gtrs have quite a bit of gunk sitting in the bottom of the tank by now.
the reason the car runs fine when its cold is that the mixture is enrichened by the ecu which compensates for the low fuel delivery when the car is warm
Edited by SLIPPERY
Well i just purchased the injectors 2nd hang which were sitting for a little while, not sure how long... and put them straight in, ill just have to get them taken out and cleaned ... weird thing is that it done the same thing with the previous injectors which were leaking fuel internaly really bad, this is what i thought the problem was ...
I might check out the fuel filter tomorrow ??
Perhaps another coil might be on its way out ??
Ill just have to get it checked out on a dyno or something ... :)
u should always get 2nd hand injectors cleaned before putting them in. FWIW, my injectors dont leak at all and i get the jerkiness so its not related to a leak, rather the squirter being a little clogged.
injectors can be cleaned for $20 each with a print out of before and after flow rate, plus a spray pattern pic.
i changed my fuel filter last week and its a 'tiny' bit better.
Long story short -
ok ... so its not the injectors, could be one of the other coils but i just wanted to know if the airflow meters would be affected by heat ? ive only just put on a set of hks airpods and ive noticed all the piping and the outside of the airpods were really hot after i come home, just wanna know if this could be the problem or perhaps an 02 sensor ? but yea the car runs perfect untill its warmed up ... then it just wont cruise nicely :)
Thanks
Max
Mate, I had similar problems, would only notice it when car is hot or being driven for a while. No doubt leaking injectors etc would contribute in your case.
Had my car checked out with a fault code finder and air flow meters were both on their way out...not completely f#%ed yet but was told would eventually die. Both of them!!!....reading different voltages above and sometimes below the norm.
Had both replace..expensive exercise and now car is running fine...no more jumpimg back and forth and lossing power.
As for the heat towards the AFM, I was told the crank case ventilation with hot engine oil mixing with air being redirected back through the air inlet causes this contamination in the air inlet and sometimes or over time the oil/heat can affect the AFMS. Recommeded an oil catch can setup to eliminate this contamination.
Oh yes, my 02 sensors weren't spot on either but was told this should not affect the driving of the car to the extend of not responding to the throttle when this happens and I would loss fuel injector signals. AFM stuffing up, telling the car that no air is coming in so fuel supply stops momentarily...car runs crap, jerks back and fourth for a few seconds, sometimes longer and then picks up again. I could actually see no fuel signal on the multi display screen when this happens.
Anyway, just something I've experienced and was told by my mechanic....that's my 2cents.
Good Luck
Naa thats awesome, ill just have to get my hands on a multimeter and have a play with the AFM's ... :domokun:
theres heaps of things for me to check / replace / fix hehe :)
:happy:
Thanks for all the replies
Good Luck
When an engine is running rich, it will run ok untill it warms up, then with the extra heat, will cause the engine to run super rich. I had a similar problem with my RB20. Piece of shit to drive, spluttering, cutting out. Turns out it had a small crack in the intercooler, wich with the afm's was causing it to run rich, and also at times, max the standard afm because of the amount of air it was thinking it was reading. Its worth a look and do a leak check..
un plug them lol :)
02 sen
It gets rather frustrating when people refuse to listen to good advise doesn't it!!!
Un plug the sensors and take the thing for a drive. Why do you think its running rich??
O2 sensor feedback perhaps??
Unplug the sensors it will take them out of the equasion and my money is on the thing running fine just as T04GTR has suggested.
Yea yea so anyway whats the deal ?? drive the car for 20 mins till it starts playin up and then unplug the o2 sensor ? or do it before?? is it hard to get too ? or will i have to take it out beforehand and take it for a drive ???
yeah. i rekon just replace everything and spend hours chasing your tale till you magicly fix it :(
do it in the garage before you start the car. you dont have to wait for 20 mins before you do it.
we all wanna know how it goes! :P
you dont need to take them out...just unplug their electrical plugs and go for a drive
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
