to tell u guys d a truth i think its the air flow meter coz my car was fine un till i replaced my broken afm wif a second hand one, im guna give that diy thread on fixing the afm ago..
will let u guys no what happens
  • Replies 45
Posted Images
I tend to agree however it should not be limited to cruise only in that case. Regardless, I had similar problems with my car.
The stuttering is most likely to be one of the AFMs with a dry solder joint. As the dry joint moves the resistance increases and as current is constant, this causes a voltage drop. The voltage drop confuses the car as one sensor is making sense and the other one is reporting very low airflow (for me it dropped to ~0.4V whereas the other AFM output was 3.0V(ish)(for comparison).
I'd have a go at Steve's DIY on AFM repair. You'll need an iron with a long tip. If you have a desoldering tool, even better.
Do you have a mate in Brisbane with a consult cable?
Okay my vehcile was giving me the shits today so I spent considerable time with consult and a multi meter diagnosing the problem instead of guessing.
This is what I have found and so far it HAS rectified my problem
The issue I was having was at cruise speeds the vehicle would feel like it was surging back and forth. There was no obscure turbo noises it would just surge as it cruised almost felt like a lean burn misfire.
Wideband showed I had reasonable cruise mixtures, 14.5:1 so its not a coil pack issue nor a MAF sensor problem which was confirmed by consult (genuine nissan consult) I had rock stead MAF sensor inputs and the A/F alpha feedback was sitting steady at 100%. Also my self learn and idle air learn was 100% indicating engine wise the thing is spot on.
If I flicked the vehicle into RWD the problem went away and it drove normally. This lead me to beleive I had some form of ATTESSA control issue.
On page CH-66 of the work shop manual (full manual not engine manual) there is a basic wiring scematic for the ATTESSA.
First thing was specific ground and power supply checks.
So on the ATTESSA control unit checked terminals 22,2,3 and 50 for continuity to ground. They all checked out okay.
Checked terminal 1 for power through the ignition.
Also terminal 39 for power from the motor relay.
Next easy to do checks are on the ABS unit under the bonnet.
The main ground for the ABS solonoid relay and the ABS motor relay is through terminal 21. CHECK THIS GROUND WELL.
This ground was the problem on my vehicle. I had a very poor ground here. As a quick check I simple spliced into the loom and ran a new ground to a 10mm bolt that was into the wheel arch. I re-checked the ground and had perfect continuity.
After a decent road test my hessitation and surging on cruise is fixed.
If you are going to do this Id suggest starting from the start and working your way through the diagrams and not nessisarily jumping straight to the ABS Ground. I found I had a bit of resistance on most of my grounds and its possible with a vehcile this old you may have a grounding issue anywhere so i suggest checking them all to avoid disapointment.
It may not fix your problem as there are many things that could cause the symptoms described in the thread but for the hour it takes to do a few basic wiring checks it may save you alot of money down the track.
Brad
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
