You know which plug it is ??
Ive got the workshop manual , looked 2nite for ages but couldnt find it anywhere !! :P
do it in the garage before you start the car. you dont have to wait for 20 mins before you do it.
we all wanna know how it goes! :)
you dont need to take them out...just unplug their electrical plugs and go for a drive
  • Replies 45
Posted Images
have a look at your 2 dump pipes. there should be what looks like a sparkplug, sticking out of each pipe. this is the o2 sensor.
now, off this sensor there are wires that lead to a plug. unclip the plug and the o2 sensor is disabled. yay!
Ok ive unplugged those 2 cables (ive attached a pic too just to make sure they were the correct ones)
Drove the car for about 20 mins and it seemed fine, going to take it out later 2nite for a longer spin to see what happens so im not 100% sure its fixed the problem. Ill post again when i get home.
Just say it IS the o2 sensors, what damage will I do if i continue to drive with them unplugged ??
Im assuming it will just run rich and use lots of fuel and the spark plugs life will be reduced ... is this right ?? or wrong ?? :( hehe ... and yea will the motor be ok to run like this over long periods of time...
Edited by chances
Naa still same problem as before with or without the o2 sensors plugged in :(
Im assuming it will just run rich and use lots of fuel and the spark plugs life will be reduced ... is this right ?? or wrong ?? :wave: hehe ... and yea will the motor be ok to run like this over long periods of time...
the o2 sensors only lean out the mixture when cruising ie constant thottle load
theyre leaning out a mixture that is already quite stoich to one that is on the lean-side that would otherwise cause detonation on higher loads. so to answer your question...it will use a little more fuel if youre doing freeway driving but not a hell of a lot more.
your plugs and everything will be fine.
depends...on fine injector openings there may only be a little bit of gunk, but just enough to obscure flow. when the injector opens a little more and for longer, then the squirt of fuel may have a clearer path through to the cylinder.
i reckon its good insurance to know that youre injectors are clean and serviced anyway rather than having to rebuild a motor cause one may eventually leak and BANG! due to starvation on boost.
Did you ever find the cause of this??
One of my GTR's has develpoed a hessitstion on cruise, I looked at it with consult today and the O2 sensors are flat lining when they should be cycling.
Strange thing is the sensors in the vehicle are only 3000Km's old and unplugging them makes no difference. I also have power and ground to the heated elements and continuity back to the ECM.
I know my vehicle needs new sensors and id suspect yours does as well. If you have access to an ossiliscope id suggest looking the at the sensors with it and see of they are cycling on cruise or not.
Yea i did ... well kinda , try taking out your 4wd fuse and take it for a spin , see if it still does it ... because mine dont when its only 2wd ... at the shops at the moment :no: ... dammit seen a few around today .. i want it baaaaack Ü
02 sensors richen the mixtures as well - under criuse condtions.
Wow just read back through all the post - man there is some misinformation here. 1 of them above the other being that cars run richer when cold as the atomisation isn't as good. Three the 02 sensor doesn't operate until about 65deg Celcius on most GTR's.
Can you descirbe the problem again please.
Edited by rob82
ok. next step.. aply a direct batery voltage to the fuel pump.
(run a wire from the batery to the fuel pump and a direct earth wire to the negative of the fuel pump aswell)
basicly to eliminate any fuel pump controler issues...wich are common
Interesting question about the air filters
Why do you ask this??
Im asuming you want to know if he as oiled filters as oposed to dry mesh types?
Mine also runs fine in 2wd but not all the time. Occasionally it gives a bit of a splutter.
I have also recently noticed the front tourqe guage goes up a little when accelerating even though its only light acceleration and the thing is not driving the front wheels.
Probably going to be a grounding issue
Edited by Risking
Is this question for me ?? :blush:
ive got a set of hks airpods ... non oil filters.
Alot of GTRs have an AFM connection problem mine is doin it now. will it hit a safe mode when driving? i had the same problem sort of too i change the fuel filter and a hose. injector clean and new plugs and regap and it still did it. heat shielded my AFM with alfoil and its good. have to do the full fix soon though started to stutter again.
mark.
dont they just 'switch off' so to speak , once an unsuitable load is detected to run a leaner mixture safely ?
anyway, i unplugged my 0xy sensors and it fixed my hesitation.
rob: i didnt think it was too far off the mark re: cold mixture. granted the exhaust gases wouldnt be overly richer, but fuel maps enrichen with cold water temps..dont they?
i think i got the same problem when i warms up wont boost past 10psi and can hear the bovs going nuts, dose this happen to u guys causing its really pissing me off, but if i turn the car off for bout 10 secs its fine again.. is this the same problem?
similar problem yes.
Do me a favour and check your ambient temp on the climate control.
When my car plays up the ambient temp is WAY higher than the real temperature. I mean it reads 32 degrees on a 10 degree night!!
Points towards a grounding problem to me.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
